[C2] Assembly line throughput
Logistically its not difficult to comprehend how an assembly line is accomplished from start to finish but most people see this as a "one of" function with magic happening elsewhere. IE, frame done, engine transmission put in, and concentration on one vehicle from start to finish occurs, whereas the magic is how you get the engine, transmission there "just in time" etc.
I always wondered what the engine shop looked like? Not the side view pictures you see but the overhead of where the heads were received, crank turned etc etc What did the test facility looked like and most importantly what happened to the engine that would not start? Was the engine started before it went into the car? Where did the car go, if it would not start later? When you see the number of cars they produced per day visions of a cattle ranch appear with a herd of good cattle sitting in the parking lot and various deficiency cattle scattered elsewhere. Must have been organized chaos at best
Then when it entered the car assembly building and was placed on the frame, it got the VIN Code stamped
But what I was getting at, was the build of the engine, was it started before leaving the plant? If so, you have build time, then move the jig to the startup facility and run in the engine because they would have to break in the cam, or was that done when the car left the assembly line?
What if it didn't start? With this many engines produced per day, still think each one of these sections or plants must have been cattle yards within themselves because there were no computers, just pieces of paper or tags attached to each unit.
The best way to explain it, is the bumper guy reached into a box and brought out the appropriate bolt to secure the bumper. His job was likely not to ensure the bolt bin was filled. Just notification it was getting low. The person filling the bin got the bolts from Person B who had an inventory of Bolts. That person got those bolts from Person C who was in shipping and receiving. No where in that scenario does the company that built the bolts play a part in the construction of the car, until, there are no bolts. So my ponderance is the logistical support from the many manufacturers who provided their product and the organized chaos within those companies, divisions, etc , and, without one computer managed to make it all work. I think it was amazing. Its a wonder there were very few assembly line shutdowns.
Material on hand used to be counted frequently. More frequently as balance out time approached for model change. Often, the material on hand was padded as a float to prevent shortages and shutdowns due to lack of material. Sometimes, the count or records were not accurate and parts had to be air freighted in at a premium shipping cost penalty.
Not a Corvette plant but the plant I worked at balanced out the 1978 model and had 5000 cars in the yard needing parts while we started building the 1979 model.
All of our engines were run on a hot test stand at the engine assembly plant before being installed in built vehicles at our assembly plant. There are many reasons a new car won't start at the end of the line. A defective engine (which was rare) was only one of them. The ones that didn't start were pushed to the side. A repairman fixed the problem and the car was on it's way.
Stop the line back then and you could look for another job or a cut in rank/pay.
Today, most all vendor plants ship parts to assembly on "just in time" schedules. Some things like tire mounting/balancing, seats and fully assembled instrument panels are built to schedule in another facility, sometimes 30-40 miles away and arrive just in time to get in the scheduled build rotation.
Sounds like your question could be best answered by studying how Henry operatied the Rouge Plant 100 years ago. Raw materials for a whole car in the back door and built cars out the front door. All self contained.
This book has some good info too. Normal disclaimer I'm not related to the book at all....
