Speedometer is not reading correct speed.
Old May 8, 2020 | 10:40 AM
Yellow6t7's Avatar
Yellow6t7
Default Speedometer is not reading correct speed.
Just recently reinstalled rebuilt M20 3885010 transmission with 8 tooth drive gear and 20 tooth blue driven gear. Rear end is 3.36:1
At 2500 RPM speed is showing 44 MPH. Should be 60 MPH. Speedometer is original to the car. Never replaced or worked on.
Prior to transmission rebuild transmission car had 3851325 transmission with a ratio adapter on the speedo cable.
Would have expected the speedometer reading close to correct with all correct components.
Do I need to replace or get my speedometer recalibrated?
Old May 8, 2020 | 11:46 AM
R66's Avatar
R66
If it worked correctly before you changed the transmission, I would look at what was changed, not what was not changed.
There are two driver gears for the shaft in the transmission that drive the plastic driven gear as you appear to know. I don't think that is it, but you might double check.
The other thing you had to change was the speedometer cable and sheath to eliminate the adapter. Is it possible the cable is too short within the sheath and not engaging the driven gear fully or you don't have the cable seated in the speedometer head or bullet in the transmission?
Just ideas
Old May 8, 2020 | 01:02 PM
joewill's Avatar
joewill
in general, your cable is spinning too slow at any given speed. you speed it up by lowering the tooth count on your driven gear.
They are cheap, get you a 17, 18 and a 19 and try them all. calibrate with your GPS speedometer app on your smart phone.
https://www.ebay.com/itm/MUNCIE-4-SP...0AAOxyQ45Q~QOQ
or try this calculator.
https://www.5speeds.com/calculators/SpeedoCalc.html
Old May 8, 2020 | 01:30 PM
6T7L71CPE's Avatar
6T7L71CPE
Wondering why the other transmission needed a ratio adapter instead of the correct gear? Are you certain the rear is actually 3.36?
Old May 8, 2020 | 10:01 PM
Yellow6t7's Avatar
Yellow6t7
The other tranny was from a 65 Fuelie with 3.73 rear end. My car has the original AM, 3.36 rear. The only way I could get the speedometer close was to use a ratio adapter. I knew this was not the best way but the speedometer was reading close to accurate. I expected that once I changed the tranny to the correct 5010 with the 20 tooth blue driven gear it would mate to the rear and the speedometer would be correct without using a adapter.
Today I've procured 17 & 18 tooth driven gears. Hopefully I will get them before the weekend and give them a try.
Old Feb 27, 2024 | 11:27 AM
Giulio D's Avatar
Giulio D
He wasn't 100 % sure but thinks 326 is what it was changed too. Is there a way to check what the actual rear end is in he car?
Old Feb 27, 2024 | 11:47 AM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
NO!!!!!!!!!!!!!!!!!!
Do not make a mountain of a molehill.
Simply replace the plastic 20teeth gear with a 18 or 19 teeth gear, as already mentioned. With the difference you have mentioned, from before and after changing the transmission, I'm thinking most like an 18teeth gear will be the choice.
They are just TOOOOOOOOOOOOOO EASY to change.
To Speedometer is not reading correct speed.
