Knock offs.....dumb question.
Old May 13, 2020 | 12:16 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Originally Posted by MikeM
Let's try this again.
Ah, but does RH refer to the thread or to the side on which it's to be mounted? Ditto for LH.
Old May 13, 2020 | 12:20 PM
65GGvert's Avatar
65GGvert
For the spinners noted in the picture, RH refers to the right hand side (passenger) and LH refers to left hand side. Don't know how that relates to right hand and left hand threads, never understood which one tightened which way. I know on the 52 Plymouth I had in high school, the passenger side lugs turned counter clockwise to tighten. I always had to stop and think about it when taking off a wheel.
Old May 13, 2020 | 12:47 PM
MikeM's Avatar
MikeM
You'd find out right quick if you tried to put a RH thread spinner on a LH threaded adapter.
I'm in the camp that believe is doesn't matter which side goes with which thread but I don't suggest anyone do other than the instructions. I have. I saw no problem.
Old May 13, 2020 | 01:09 PM
jim lockwood
You'd find out right quick if you tried to put a RH thread spinner on a LH threaded adapter..
I know what happens if an attempt is made to put a RH thd spinner on a LH thd adapter.
I asked the question because the KOs I have aren't like the ones in the pic and I have no first hand experience with the ones you show.
Old May 13, 2020 | 04:26 PM
MikeM's Avatar
MikeM
This is not a perfect world! But for those that are confused about which is what, best get some spinners like these.
Old May 13, 2020 | 04:28 PM
jim lockwood
Or, you could just answer my question.
Old May 13, 2020 | 05:12 PM
A-Snake's Avatar
A-Snake
I have a car with center lock hubs. The easy way to remember how to tighten is to remember the phrase "Tight ***" The knock-off should tighten when rotated toward the rear of the car.
Old May 13, 2020 | 06:42 PM
MikeM's Avatar
MikeM
I have no first hand experience with elements of your question. Now what do we do?
Old May 13, 2020 | 07:46 PM
ragedout's Avatar
ragedout
it seams like there is no right or left way to do it. ??
Old May 13, 2020 | 08:16 PM
Oaker57's Avatar
Oaker57
Originally Posted by Critter1
The torque spec for the KO nut/spinner is 450 lb ft. Not at all likely to fall off at that amount of torque. Wasn't it "eight blows with the supplied lead hammer" in the owners manual?
I've driven cars with KO wheels all over this country and never had one come loose.
Edit: Found the (original) KO wheel instruction card that came with a 65 that I once owned. I'm pretty sure reproductions are available.
Those instructions about the 8 good whacks always had me wonder.......Wouldn't the 6'5", 250lb guy's 8 whacks be quite different than the 5'3" 145lb guy's 8 whacks.? I give mine a lot more than 8, and also make sure they were started when off the ground so they seat properly, then finish them on the ground to get them good and snug.....Just makes me feel good anyway..!
Old May 13, 2020 | 08:18 PM
Oaker57's Avatar
Oaker57
It "seems" like you must be talking about sewing or something??
Old May 13, 2020 | 09:22 PM
Critter1's Avatar
Critter1
Well, I suppose that's why some wheels fall off because they're not tight enough and some crack around the nut seat because Bruno the gorilla installed them.
I can hear when my KO spinners are tight when I hit it with the hammer. They make a different sound when they get to around the correct torque.
Old May 13, 2020 | 09:25 PM
  #33
pop23235's Avatar
pop23235
Well, I'll try this again. My post disappeared.
The instruction card above, plus the adaptors are marked, use the correct long lug nuts, the spinners are marked. How can anyone not get this right? But, it won't go away here for some reason.
Old May 13, 2020 | 09:58 PM
  #34
Critter1's Avatar
Critter1
I don't have a 64 AIM her to find the revision but I think the first sets of KO's installed at St Louis were installed with the original length/short lug nuts. KO wheels could easily be installed incorrectly, over the lug nuts instead of being correctly indexed over the pins. That's why the long nuts were added in production.
I think you're right about the adapters being marked left or right?
When I first dropped in here to the CF about ten years ago, it seemed like half the pictures of cars with KO wheels had the adapters/spinners on the wrong side.
Old May 14, 2020 | 03:13 AM
  #35
MikeM's Avatar
MikeM
Exactly!
Old May 14, 2020 | 06:09 AM
  #36
Critter1's Avatar
Critter1
Exactly!
Yup, you know the sound. I knew you would.
Old May 14, 2020 | 07:07 AM
  #37
Critter1's Avatar
Critter1
I think I know why the KO spinners were shown as being on the wrong side in many early release GM photos. I have the original print for the early release spinner and only one part number is shown but the OFF characters with arrow would be stamped depending on which thread it would have, left or right.
In all the GM photos that 427 sidepipes posted, (post #13) all the spinners on the right side are correct but those on the left side appear to be incorrect for that side. Just like in my print. Only one side was made but threaded either left or right and the correct arrow added to the stamped OFF characters.
I think we figured it out.
To Knock offs.....dumb question.
Old May 14, 2020 | 07:32 AM
  #38
kandbstewart@comcast's Avatar
This has been a good help to understand working with KNOCK OFF WHEELS. Thank you for the information. Ken Stewart
Old May 14, 2020 | 08:08 AM
  #39
DansYellow66's Avatar
DansYellow66
Yeah, it’s been a few months since we last had a good old knock off wheel free for all.
it’s a regular event.
Old May 14, 2020 | 10:07 AM
  #40
19sleepy65's Avatar
19sleepy65
Wow! not a dump quistion after all!
