[C2] First Glitch Installing Engine
Last night I was focusing on the water pump along with A/C bracket (Right side) and alternator bracket (Left Side). Houston, we have a problem. Seems the Brodix heads are just a tad wider than stock heads. I am about 1/4 off on having all the brackets line up.
I am using Fel Pro 1404 exhaust gaskets and they are about 1/8" thick. So my question is this.....
1. Can I run stock manifolds with aluminum heads and no gasket? While this won't give me all I need it will help. If I do not run a gasket what should I use as a sealer?
2. There is enough meat on the alternator bracket to open the 3/8 hole up or move it slightly over. This might work and I think there is plenty of strength left.
3. The A/C brackets are another story. They are cast not stamped parts. I could consider shaving about a 1/8 - 3/16 off the bracket that mounts up against the ex manifold, then open up the two 3/8" holes on the cast part that mounts to the water pump as well as the 3/8 hole that mounts to the exhaust a/c bracket.
I really hate bubbageneering this but I have racked my brain in looking at other options. I plan to call Brodix and discuss with them as welll.
If I go down the path of doing the above modifications I will just order Repro brackets and bubba them. Not the originals.
I know there are lots a brains out there so maybe there is a solution I am missing. Thanks for any suggestions.
Thanks, John
P.S. I can machine the bracket mounting surfaces on my mill if you prefer. Or fabricate a whole new piece.
One of the things he did state is the ports are .200 higher than stock. And they are cast at 23 degree plane and that might be what the problem is. Surely I can't be the only person to install these heads on an A/C Car?
I have sent them some pics so we will see if they have a suggestion, but I am pretty sure it will be up to me to solve.
There are no spacers being used at all to mount to engine.
The mounting bracket that bolts to the ex manifold mounts flush to manifold. The part that looks like a spacer is actually a double ended bolt and the exact size as the OEM bolt. The bracket that mounts to the water pump mounts flat to the bolt bosses as well. I appreciate the offer for milling this and I might reach out to you as a last resort. Thanks so much for the offer.
Maybe this is a better pic of a correct mounting.
Patrick
I will have a look.
The solid copper gaskets are only .041" thick. That might do it. That's pretty darn thin and copper seals great and works well with aluminum.
Michael
Mark I don't get the special gasket for an aluminum intake on iron heads. All we ever used and I still do today is a 1204 Fel Pro. Never had any problems.
Thanks for the info. Since my Brodix heads are "suppose to be in the stock exhaust position", I should not run into the issues you are seeing. Hopefully, if I ever get motivated to install the new motor.
Best of luck in solving your issues!
Plasticman
The other problem is the alternator bracket is just not gonna go unless I massage the bracket. Looks like I will have to become very intimate with a rat tail file and work all three mounting holes for the water pump bolt and the two exhaust manifold bolts. That problem will be delayed till I get back from Florida. I am going fishing!
I appreciate all the feedback!
Repro on Left, OEM on right. What a difference! Stupid me should have checked.
After I put the original OEM integral nut bolt in.Close and workable. Not perfectly aligned but can get a bolt through both holes now.
This shows how far off the repro fastener was.
This is the next problem to solve. I have to massage the two holes to mount this to the manifold.
Hard to see but you tell the bolts not going in without some opening up.
