Alignment shins
Old May 23, 2020 | 08:29 AM
charbon98's Avatar
charbon98
1st Gear
Default Alignment shins
Hello , just new to the group , any of you experienced loosing the alignment shins while driving ? Is there a way to keep them in place ?
Old May 23, 2020 | 08:39 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
from the a arms or traling arms?if trailing arms use the correct mid year shims and they can't come out. if your using the latter C3 ones you must drill a hole in your frame for a cotter pin
Old May 23, 2020 | 09:40 AM
C2Scho's Avatar
C2Scho
Hi Charbon98,
Like Nowhere Man said, it depends on whether you are talking about your A Arm shims or your Trailing Arm shims. Here is a relevant thread if you happen to be referring to Trailing Arm shims. Let us know which it is and we can provide more detailed information accordingly. Cheers. C.J.
https://www.corvetteforum.com/forums...-pavement.html
Old May 23, 2020 | 11:01 AM
C2Racer's Avatar
C2Racer
Pin the trailing arm shims no matter what. Easy insurance.
To Alignment shins
