Idle issues
Old May 24, 2020 | 02:54 PM
Seabeast's Avatar
Seabeast
6th Gear
Default Idle issues
I rebuilt my Carter AFB carburetor last night and got it put back on this morning. It idled perfectly when I initially started it up. I took it for a drive and it started to get very rough at idle and when I returned back to my garage, it would not idle at all. When I give it gas it stays running but as soon as I let off it stalls out. I did notice that the pcv valve was rusty on the inside and I tried to clean it up the best I could when I rebuilt the carb. Could this be a potential reason why the car will not idle? Any other thoughts would be very much appreciated.
Old May 24, 2020 | 04:01 PM
tbarb's Avatar
tbarb
It could be if the pintle inside the PCV valve is sticking open allowing excess air into the engine at idle.
Pull the rubber hose off and plug the end of the valve then start the engine to see if the idle is better. It may be a bit lower than normal but should not stall.
Old May 24, 2020 | 07:08 PM
Seabeast's Avatar
Seabeast
6th Gear
Plugged the hose and no luck. The car still stalls out. When I rebuilt the carb everything was cleaned and only the gaskets were changed. I have made many adjustments to the idle mixture screws and it’s always the same result. Sounds like I may need to pull the carb back apart. Any other ideas of what to look for?
Old May 24, 2020 | 07:41 PM
Donald #31176's Avatar
Donald #31176
You might have picked up some trash at the needle & seat or the float maybe stuck open. Try rapping the carb lightly with a rubber mallet to free float.
Old May 24, 2020 | 08:02 PM
Pilot Dan's Avatar
Pilot Dan
Exactly, what's the condition and age of your gas tank and fuel filter.
Old May 24, 2020 | 08:33 PM
Seabeast's Avatar
Seabeast
6th Gear
The fuel tank is about 10 years old and I replaced the fuel filter when I rebuilt the carb so it is brand new. I have looked in the gas tank and there is no corrosion or debris.
Old May 24, 2020 | 08:40 PM
Pilot Dan's Avatar
Pilot Dan
Probably then a float issue. I'd remove the carb and re check the floats for debris and adjustment. Possibly a piece of trash from the rebuild that found it's way to one of the needle seats. Blow it out with compressed air and reassemble.
Old May 25, 2020 | 07:28 AM
DansYellow66's Avatar
DansYellow66
Might try removing the idle mixture screws and spraying carb cleaner with a straw back through the idle circuit to see if it might dislodge sone junk in it. If it does then the the carb and/or fuel line probably needs some more flushing.
Old May 25, 2020 | 09:16 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Choke issue?
Old May 25, 2020 | 09:17 AM
R66's Avatar
R66
Can you keep it running by choking it or squirting fuel into the primaries? This will help troubleshooting.
Do you have to choke it to get it to restart or pump the accelerator?
May have sucked a carb/manifold gasket due to loose installation torque or warped base plate creating a vacuum leak.
What was the reason for the rebuild?? How did it run before you did the rebuild?
Old May 25, 2020 | 10:50 AM
Seabeast's Avatar
Seabeast
6th Gear
Thanks for all of the responses.
The car had been sitting for quite a while and actually ran really well before I started the rebuild. The carb was dirty externally and I figured while I had it pulled off the car for cleaning, I would just rebuild and make sure everything was clean and gaskets fresh.
After pulling the carb apart again, I noticed that the float drop was way too large (>1"). I have made the proper adjustments (23/32"). I have not had a chance to install the carb back on the car, but I would assume/hope this would solve my issues.
Old May 26, 2020 | 04:01 AM
davekp78's Avatar
davekp78
Check the heat riser valve, also.
To Idle issues
