Exhaust
Old Jun 14, 2020 | 10:36 PM
Brookdale's Avatar
Brookdale
Default Exhaust
Our car has been stored for approx. 25 to 30 years, it's a 327, 300 hp. Thanks to the advice of many members on this forum, we were able to get it started and running. For some reason the exhaust out of one tail pipe is much stronger than the other side. The side where its coming out stronger appears to be dry, where is the side with less pressure appears to have some moisture. We are not mechanics and are learning as we go along, any advice would be appreciated.
Old Jun 14, 2020 | 11:34 PM
GUSTO14's Avatar
GUSTO14
If the stronger side is on the driver's side, it is probably the result of a stuck heat riser valve on the passenger down pipe.
The heat riser valve is spring loaded closed (and can rust in that position if not moved over an extended period) and designed to direct exhaust gas from the passenger exhaust manifold through a channel below the intake plenum to the driver's side exhaust to warm the engine sooner. If the valve is stuck it can significantly resist exhaust flow and impact engine performance.
Look for the valve at the exhaust manifold and try to move it to break it loose.
Good luck... GUSTO
Old Jun 14, 2020 | 11:38 PM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Here's what one looks like - of course the exhaust manifold is above it and the pipe is below but what GUSTO is talking about is that square weight. That should be loose and able to be moved up and down. You can see what effect that will have on the exhaust flow as the butterfly either opens or closes.
Old Jun 15, 2020 | 12:44 AM
Brookdale's Avatar
Brookdale
Thank you Gusto and Railroadman, you're right, the exhaust is coming out stronger on the drivers side. We did actually see the valve you're referring to on the passenger side under the exhaust manifold and was able to move it up and down, but had no idea what it was until you explained it. We moved it by hand, again, had no idea what it was and not sure what position we left it in but will try moving it again the next time we're able to work on the car, and check the exhaust on the passenger side. Thank you again, we really appreciate your help.
Old Jun 15, 2020 | 02:20 AM
facelvega's Avatar
facelvega
My C2 from 67 has this valve as well.
I thought the valve was supposed to have a control function for the choke.
My engine has an electric choke and so I opened the valve permanently, because I don't see any sense in its function.
Maybe I'm wrong, but my car is only moved in nice weather and warm temperatures.
Old Jun 15, 2020 | 08:43 AM
Railroadman
Brookdale, the purpose of that doohicky is to help the car warm up faster. When it's cold, it should be shut and thus sends the RIGHT side exhaust up, through the intake manifold, and down out the driver's side. As the car reaches operating temperature, it should open allowing more equal flow.
So if the car is cold (as in "not having been driven for a while", NOT as in "15 degree weather") it may still be OK - try letting the car idle for a while, or take it for a short ride, and see if the pressure is more equal.
Old Jun 15, 2020 | 08:56 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
The heat riser is the obvious place to check, but if the car has been sitting/stored for 25-30 years, you could have mouse nests/rust/deterioration in the passenger muffler. The passenger muffler rusts out first because of the heat riser.
I've blown several mouse nests out of tailpipes starting cars that have been sitting for a few years.
Old Jun 15, 2020 | 10:56 AM
phil2302's Avatar
phil2302
O/P you can gut that riser and put it back in minus the moving flap and you will not have to worry about it getting stuck closed again.
Old Jun 15, 2020 | 12:29 PM
AkrHack's Avatar
AkrHack
I had the same symptom on my '67 with side pipes. Instead of wiring the heat riser in the open position, I replaced it with a spacer that has the same thickness. After doing that, condensation no longer drips from the right side pipe.
Old Jun 15, 2020 | 02:12 PM
Railroadman
Paragon part # 730: "Exhaust pipe spacer. RH, 2" . Substitute for heat riser valve. $45 "
To Exhaust
