[C2] Upper Control Arm
Old Jun 15, 2020 | 03:55 PM
66softtop's Avatar
66softtop
Default Upper Control Arm
Is there a difference between the 1965 and 1966 control arm cross shaft. Particularly the bolt holes. I've seen round and also square.
Old Jun 15, 2020 | 07:08 PM
DansYellow66's Avatar
DansYellow66
Square bolt holes or square shaft sections that the bolt holes are drilled in? I know there are two types of shafts one with square bolt pads and one with rounded bolt pads. Not sure if the years have been pinned down exactly for each. If you really mean square reamed bolt holes - guess I've not seen that before.
Old Jun 15, 2020 | 07:54 PM
66softtop's Avatar
66softtop
Square and round bolt pads is what I meant to say. Just doing some restore on my 66 and found mine have the square pads. I seem to have read somewhere that the square were for a 65 vette and the round for a 66. My question comes from the fact that my 66 has the square one and wonder if it is correct.
Old Jun 15, 2020 | 08:12 PM
bauto's Avatar
bauto
if your car is an early 66 then it will have the square upper control shafts, not sure what the cutoff is but my car was built oct 8th and has the square ones
Old Jun 15, 2020 | 09:31 PM
R66's Avatar
R66
Late December 65 car here has rounded bars
Old Jun 16, 2020 | 12:29 PM
66softtop's Avatar
66softtop
Mine was built May 66 and I have the square tabs.
Old Jun 16, 2020 | 12:53 PM
Dislocated's Avatar
Dislocated
My ‘66 was built in mid December 1965 and has square bars.
Old Jun 16, 2020 | 02:47 PM
DansYellow66
My winter of 66 car had one of each. But I can’t be sure one hadn’t been replaced at some time since it had taken a hit up front at some time.
To Upper Control Arm
