1963 automatic exhaust
Old Jul 2, 2020 | 05:10 PM
Ageorgecp's Avatar
Ageorgecp
Default 1963 automatic exhaust
I keep seeing online that the aftermarket exhaust systems are listed as 2” (base or auto) and 2.5” (manual). Can I not put a 2.5” exhaust on my 63 if it’s an automatic? I can’t see any clearance issues but then again I don’t have a lift to really get under it. I was hoping to upgrade to headers and the larger exhaust. Has anyone done this?
Thanks!
Old Jul 2, 2020 | 05:23 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
I can't think of a reason that wouldn't work.
I've had a '63 with 2.5" exhaust and I have one now with 2" exhaust and I've been under both cars (altho not recently).
My memory is there is plenty of room.
Old Jul 2, 2020 | 05:29 PM
426 Hemi's Avatar
426 Hemi
I put 2.5" on my '63. I had to do a fair amount of heat and beat to clear the rear corners of the PG pan. More so on the passenger side. Running a 4 speed now.
Old Jul 2, 2020 | 05:46 PM
Ageorgecp's Avatar
Ageorgecp
any idea how much it would cost to have a shop do an exhaust system? I don’t have the ability to do any welding at home. I’m in California for reference. Just trying to get an idea of the best way to approach this (the car is new to me and my first older car/corvette)
Old Jul 2, 2020 | 05:53 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Buy the correct system and there is no welding needed Just bolt it up and go
Old Jul 2, 2020 | 06:10 PM
Ageorgecp's Avatar
Ageorgecp
Any recommendations on where to get the system from? I was thinking about going with a slightly more aggressive muffler (maybe a flowmaster 40 delta flow)
Old Jul 2, 2020 | 06:33 PM
Nowhere Man
corvette central N11 system would be my choice. Flowmaster series 40’s belongs in the dumpster
Old Jul 2, 2020 | 06:42 PM
vark_wso's Avatar
vark_wso
Thanks!
The passenger side exhaust pipe (manifold to & thru cross-member) made for a manual transmission -- either 2" or 2-1/2" dia -- will not have clearance around the Powerglide's bulky case & pan. The other 3 pieces could be accommodated with correct hanger ***'y, clamps and the like, but the RH pipe will have to be fabricated if you go this route. If you have a late '63 equipped with trans fluid cooler/heat exchanger, those two lines provide another obstacle to RH pipe routing.
Ageorgecp's Avatar
Ageorgecp
I have literally no experience with it, so just curious why you think they are trash? Any insight is helpful. Thanks for the tip about the N11
Old Jul 2, 2020 | 06:47 PM
Nowhere Man
Had them on my first car and the drone was horrible
Old Jul 2, 2020 | 07:06 PM
Ageorgecp's Avatar
Ageorgecp
gotcha. How does the N11 muffler sound? Compared to the 2” stock, how will the 2.5” compare?
Old Jul 2, 2020 | 07:25 PM
Nowhere Man
The N11 has a nice rumble The base mufflers sounds like a mundane passenger car
Old Jul 2, 2020 | 07:31 PM
Ageorgecp's Avatar
Ageorgecp
I notice that corvette central has both the N11 as well as a magnaflow set. Any thoughts on the magnaflow?
Old Jul 2, 2020 | 07:39 PM
Nowhere Man
My dad had Magnaflow on a 91 Corvette and I thought it sounded great.
Old Jul 3, 2020 | 12:31 AM
Ageorgecp's Avatar
Ageorgecp
I have an early 63. So would it be worth buying a kit and then taking it to be altered? Or just have an exhaust place do the entire thing?
Old Jul 3, 2020 | 08:38 AM
morly1963's Avatar
morly1963
I have a 63 with auto-bought a 2.5 exhaust. Its been on since 2001 and no problems.
Old Jul 3, 2020 | 12:14 PM
65 Pro Vette's Avatar
65 Pro Vette
C2 of Year Finalist (appearance mods) 2019
Unless you have a very high performance engine in your 63 going from 2 inch to 2 1/2 inch is not going to make any difference in the performance of your car. You can get mufflers that will sound great with the 2 inch exhaust system. As stated the pipe on the passenger side front gets too close to the oil pan of the automatic and heats up the transmission.
Old Jul 3, 2020 | 01:05 PM
CorvetteMikeB's Avatar
CorvetteMikeB
Thanks!
Get stainless steel pipes & mufflers.
Either the 400 series or 300 series stainless steel metal.
You will never have to replace them again.
The galvanized aluminum is stock grade and "junk" they used in the 1960'S-1980's and rust just sitting in the garage.
The only thing is stainless steel would not pass judging and lose points if that is what you are into.
Not me, I want modern stainless steel used in today's cars and trucks that usually outlast the rest of the vehicle.
Old Jul 3, 2020 | 01:07 PM
Ageorgecp's Avatar
Ageorgecp
do you have a recommendation for which muffler if I just keep the 2” pipe? It looks like it has the stock exhaust with the exception of headers that a previous owner installed on it. I’m not too concerned keeping things stock (it has a CE engine in it) but will obviously hold onto any stock parts.
To 1963 automatic exhaust
