LS3 Rear Driver PCV???
Old Mar 10, 2022 | 12:26 PM
Patrick03's Avatar
Patrick03
Drifting<br><img src="/forums/images/ranks/2k-3k.gif" border="0">
Originally Posted by ernbug1956
This seems to contradict itself. It tells you to mount your hose in the air intake between the the MAF and throttle body. Then it says if the MAF sensor does not read this it could cause problems. Where exactly should this go? Should it be between the MAF and fresh air intake (filter) or between the MAF and throttle body? Confused.
Must connect between MAF and throttle body. Just follow the air flow and it will make sense. All the air consumed by the engine goes through the filter and past the MAF. The MAF measures this air flow. A small amount of air is diverted to go through the PCV system. The majority goes to the throttle body. That small bit of air goes through the crankcase and then back to the intake (after the throttle body) to be consumed by the engine. So in the end, the engine does get all the air the MAF measured, which is what you want.
Patrick
