adding 65 BB POWER brake booster question
Old Sep 4, 2020 | 03:04 PM
mavanlake's Avatar
mavanlake
Default adding 65 BB POWER brake booster question
I am currently starting to add a power brake booster to my BB 65, the question I have, are the 2 mounting bolts/ studs that connect the old pedal box to the Master cylinder, how do you remove the 2 studs from the pedal box,, power booster all-ready has the 2 studs in place. are these studs pressed in or can I drive them out with a mallet? (BFH) the ones on the power booster are "pressed in ?" the same as the old studs from the pedal box,, which 2 studs' need /should be removed, the ones from the pedal box, or the new booster to fire wall of course no directions and the AM does address this issue for me. If anyone has done this conversion please advise. Much Appreciated.
Old Sep 4, 2020 | 03:42 PM
mavanlake's Avatar
mavanlake
These are the studs I was asking about, which ones should be removed and how
Old Sep 4, 2020 | 03:58 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
if memory serves me you remove the ones on the pedal box and they are pressed in like wheel studs. don't forget to remove the return spring in the pedal box for the brake pedal
Old Sep 4, 2020 | 04:46 PM
edupere's Avatar
edupere
As Nowhere Man says you punch out the studs in the pedal box. Note that the clevis on the booster does not go into the same upper hole on the pedal arm as the manual brake clevis. The booster clevis goes in the lower hole. The upper hole is then used for a brake switch striker plate, which you may be able to do without since the switch will likely strike the pedal arm anyways. You will have to adjust the switch to ensure proper brake light function. If you have an AIM refer to options UPC J50 for assembly detail.
Old Sep 4, 2020 | 05:54 PM
mavanlake's Avatar
mavanlake
thanks, but wouldn't you have to remove the entire pedal box assemble to get to the two studs ?? What is the best way to "Punch" these out? Tried to use a vice and socket setup to see if the Brake booster studs could be removed easily, but no go. there in there tight.
Old Sep 4, 2020 | 06:03 PM
edupere's Avatar
edupere
No need to remove pedal bracket, just hammer out the two studs. They have serrations on the shank where they go thru the bracket and are just a light press in. Pretty easy to hammer them thru from the outside. They will fall out on inside. Put a nut on the end of stud to hammer on to avoid damaging thread in the event you wish to save them. If you have trouble, check to make sure someone hasn't welded them in on the back side, I have seen this done before. If that's the case you likely will have to remove the pedal bracket.
Old Sep 6, 2020 | 02:34 PM
mavanlake's Avatar
mavanlake
Thanks, they punched out a-lot easier then i thought they would. One more question, someone mentioned that the brake pedal return spring needs to be removed ??? i don't have a typical coiled spring on my brake lever, just the one at the very top of the pedal box a wound type spring, not sure way it would have to be removed. Thoughts, thanks again!
Old Sep 6, 2020 | 03:11 PM
edupere's Avatar
edupere
You do not need to remove the pedal or the return spring for this.
Old Sep 6, 2020 | 04:30 PM
Nowhere Man
you do if you want it to look factory
Old Sep 6, 2020 | 05:03 PM
edupere's Avatar
edupere
Yes, if your car has NCRS judging in its future you should remove the spring since they weren't used in original 65 & up PB cars. However, leaving it in won't hurt function at all. If your car is a driver its easier to leave it in.
Old Oct 28, 2020 | 11:22 AM
mavanlake's Avatar
mavanlake
completed the Power brake Addition to my 65 BB, WOWOW! what a difference!!! the car now brakes (almost) as good as a modern car! never imagined it would make such a HUGE difference in braking, drivability, and confidence, its a new car .
Thanks for all the help and advice with this project!
Mark
Old Oct 29, 2020 | 11:48 AM
65-L78's Avatar
65-L78
C2 of the Year Finalist - Unmodified 2020
C2 of Year Finalist (stock) 2019
Anyone know where to find a set of those press in studs? During my restoration one of mine went misplaced. Searched most of the parts catalogs for a set of those!
To adding 65 BB POWER brake booster question
