Matching Numbers?
My car is a 1964 Convertible, 300HP, and I was told that it is a matching numbers car. I have a lot of documentation/receipts with the car and know that it has a lot of replacement parts on it so probably wouldn't score very high on an NCRS judging but I'm curious. I'd like to locate the various stampings/tags and evaluate them for myself. I really don't want to do a full NCRS scoring, just a better understanding of how original it still is.
I have the names and sales documentation for each of the four previous owners. The first owner bought the car new in Nashville, TN and kept it for 25 years, selling it in 1989. Owner two kept it for another eight years. It must have been rough when he sold it. Owner #3 bought it in late 1997 and immediately spent two years restoring it. I have many of his receipts and an itemized list of what he did and how much each thing cost him. It looks like the drivetrain was rebuilt and much of the interior was replaced. There were a ton of miscellaneous parts replaced. I know he used the Noland Adams guide because it was in his itemized list of things he bought for the car. The body was painted in 1999 or 2000 and is still the original color. I don't know how much body work was done to it before painting but I know the hood sags now and is on my list to have repaired.
After restoration, owner 3 kept the car until 2017 when he sold it after 20 years. Owner #4 drove it for one summer and then stored it for two years due to personal issues. I bought the car a few months ago so I'm now owner #5. I plan to keep the car as long as I'm healthy and able to keep it running. Given my age that could be another 15 years or maybe more if I'm lucky. Therefore I'm willing to put a few dollars into the car at this point.
I've started taking care of all the deferred maintenance items to get it back into reliable driver condition. I've found a good local shop that's doing much of it but I'm doing some of the easy work myself. I'm also considering making a few upgrades to improve the drivability of the car but before I do I'd like to understand the car a little better, hence my question about numbers. I'm torn between working toward an all stock restoration since it's almost that now or doing just a few modernizations along the way.
So a couple questions.
What numbers should I look for to see if they are truly matching? How do I cross reference them?
What things if any would you prioritize to upgrade for a reliable weekend driver?
Thoughts?
I'm not planning to modify much. It was suggested that I put gas shocks and electronic ignition on it. I'm going to put new wheels and tires on it for a better look. I don't like the tires it has now.
To be honest I prefer it being mainly original. I've never owned a Corvette before but drove a 68 firebird in high school. It reminds me of that car even though I haven't owned it for over 40 years.
I found a used "by the numbers" book on Amazon and ordered it. Thanks for the suggestion.
You might find the thread interesting:
https://www.corvetteforum.com/forums...-matching.html
There will be some differences between a 65 and 64 car, but, for the most part, it should be helpful to you.
I learned quite a bit searching for the numbers and date codes on my car.
And, I still have some more things I'm going to check and add to that thread one day.
OP youll see some guys post up pics and tell you how to check for them. Fix your car YOUR way not how someone off the internet tells you to.
1) Engine VIN Number. Lets suppose its 000001 you lucky dog
2) The Transmission should be S000001
3) The Vin on your car would be XXXXXXS000001
but
Matching also extends to the ****
So for instance, if your car was S000001 then it would have been made in September which has a Letter attached to it
So the letter lets assume is K
Then your Rear End, would have to have a stamp before K and the Gear insertion would have to be before the actual build date
Then your Alternator must be dated correct, Carburetor, etc etc
So Matching Numbers and a Correct Car can be separated with the **** part of Restoration, which is Nut bolt correct also.
When you get to nut bolt correct, you turn into a NUT (personal experience). You can have a bolt that is correct for every month but K, perhaps because of a shortage or a supplier change. So the bolt may have a headmark of WB but your car was produced while they were using the same bolt but with headmark TR
Get the point?
I also have an assembly manual coming because I want to replace the seat belts and couldn't find that in the shop manual. I read on here that the A.I.M. is the book for that.
I considered buying an NCRS judging guide but figured that would be way too deep. Sounds like I should just go ahead and get it.
When I was young my dad was my book. He taught me most of what I did with my cars back in the day. He's been gone for over 25 years now so he can't show me anymore. I considered myself a motorhead in high school and then went to college and became an engineer. Now I'm a couple years from retirement and trying to relearn things I once knew. This will keep me busy I believe.
Just asking since I also am a new 65 owner and trying to find a good source of reference materials.
