Problem starting
Old Sep 26, 2020 | 08:57 AM
mintcondition's Avatar
mintcondition
Default Problem starting
I have a ‘59. I rebuilt the starter, new solenoid, new battery. Starts great. A week later it’s stone dead, no clicking or cranking. When the key is at the on position I hear a whirring like a small motor (wiper maybe). I tested the battery voltage using a tester, tested the load when trying to start. Everything good there. Lights are bright, interior lights work, horn works. Checked wires, were tight at the starter. I know that the ignition key is the start of the juice, seems like it is not getting anywhere from there.
One day starts perfect, next day dead. HELP please!
Old Sep 26, 2020 | 09:06 AM
mintcondition
Ok, so it’s the next day and now it started with no problem. Where is my problem?
Old Sep 26, 2020 | 09:09 AM
Panama 58's Avatar
Panama 58
Are you saying that something is killing your battery, or that the starter is dead. Does the whirling noise happen when you try to start it? If the starter drive doesn't engage it will make a whirling noise, but it will not drain the battery (if that is what you are saying). Have you check the starter drive gear?
Old Sep 26, 2020 | 09:16 AM
mintcondition
I just had the starter rebuilt, new solenoid, and battery is also new and tested. The whirring noise is the wiper Motor when the key is at the on position. I turn the key to start And nothing.
Old Sep 26, 2020 | 09:44 AM
MikeM's Avatar
MikeM
How do you know where the juice is/isn't? A 12 volt test light could tell you quite a bit.
Old Sep 26, 2020 | 11:14 AM
CorvetteMikeB's Avatar
CorvetteMikeB
Problem starting?
Me too! Until I have my coffee in the morning and before I eat breakfast.
To Problem starting
