[C2] Timing problem
Old Oct 12, 2020 | 06:53 AM
Paul1966's Avatar
Paul1966
Default Timing problem
1966 427/425,,,all stock. I have a miss at idle. Timing light will steady up but I see it jump . I have replaced the wires, plugs, rotor and the cap but the problem remains. Even started it up in a dark garage and I do not see any " fire ' jumping . Any and all comments would be appreciated. Thanks
Old Oct 12, 2020 | 08:07 AM
DansYellow66's Avatar
DansYellow66
Sounds like you don’t experience a miss while driving it - is that correct - only misses at idle? Is it stock TI?
Old Oct 12, 2020 | 02:39 PM
Paul1966's Avatar
Paul1966
Runs fine , does not jump when I increase the RPM. Thought the problem was in the K66 so I installed a Pertronix unit . Same problem. Does start better with that unit but I am going to reinstall the K66 for originality.
To Timing problem
