[C2] Valve cleaner
In the OP case he clearly states the engine runs great, leave it be.
What I found was that the deposit added weight to the valve and caused them to float at high RPM. Bought a 63 SS in San Diego from a old guy and had trouble getting it over about 45 hundred RPM. I was driving it to Anaheim and I pushed the he!! out of it and there were burnt things coming out of the tail pipe, Burnt carbon. It was high mile engine with worn guides and the intakes were caked with the carbon when I tore it down.
Also if you remember they were using chrome rings and the old folks would bring the car back to the dealer saying it was burning oil, which it was. The fix was fun. Service manager said to drive it to the freeway and beat the hell out of it. Those rings were discontinued, but a few good runs would seat them.
Dom
One night I looked out the rear view mirror as I approached 6500 in third and saw a trail of glowing orange particles behind the car that were actually still glowing as they hit the pavement and bounced off. I immediately backed off and drove slowly back to my apartment thinking that something inside the engine was disintegrating. The next several times I drove the car I "heard noises", but finally realized it was just my paranoid imagination.
My final conclusion was that the 15-20 seconds of 1500 degree exhaust blowing through the exhaust system at very high velocity was simply heating up and knocking off hot carbon particles from the combustion chamber to manifolds and upper exhaust system and out the tailpipes. At the time I had straight through glasspacks, so there was nothing to impede the flow of hot glowing particles. The OE type reverse flow mufflers probably would have trapped them or cooled them enough so they were no longer glowing as they exited the tailpipes.
Jim - Yes, I have no doubt who gave you the Chevron Richmond research facility tour.
Duke
Studies of inlet port flow using smoke or other markers show a large dead area between the valve head and stem at both low and high lifts. That's because the mixture follows the path of least resistance from the port to the annular opening between the edge of the valve and the seat, which leaves a volume of "dead air" in the shape of a cone from the top of the valve head up the stem, and this is one reason why deposits build up in this volume because there is no high velocity fuel air mixture to wash them off.
The exhaust valve situation is similar as the flow must go around the edge of the valve leaving the top of the valve with dead air and since the exhaust valve runs hotter than the inlet any deposits, like from oil down the guides, carburizes.
This brings up an interesting point about Rochester FI system. The nozzles are aimed directly at the top of the inlet valve, so there is a continuous flow of liquid that modern detergent gasoline should keep the top of the inlet valve clean compared to a carbureted or direct injection engine.
Duke
