Engine Block Numbers
Old Oct 31, 2020 | 04:00 PM
ed427vette's Avatar
ed427vette
I think the factory VIN font for the number 4 is supposed to be closed on top, not the open 4 as the OP has.
Old Oct 31, 2020 | 06:33 PM
GearheadJoe's Avatar
GearheadJoe
Yes, the "4" is the font that looks the most different from known-original VIN derivative characters I have on file. I think the "2" and the "5" also look different, but the "4" really stands out. The photo below shows the typical "2" and "4" fonts:
Old Oct 31, 2020 | 07:36 PM
JohnZ's Avatar
JohnZ
Originally Posted by Redbird
Isn't the "1" in the assembly date supposed to be a capital "I"?
Yes. Engineering notified the Engine Plants in early 1957 to use the capital "I" character instead of the "1" number character in the engine plant-applied assembly date stamp; compliance varied, but that was the direction given.
Old Oct 31, 2020 | 07:41 PM
Jeffthunbird's Avatar
Jeffthunbird
I’m not an expert but I agree with gearheadjoe. I think the 711 are original and possibly the 5 and the 442 were punched after the block was ground enough to remove the original. Is the pad not flat in that area? The 4 font is bad and the 5442 seem to droop down. I think they were individually stamped but fairly well done. This pad would fool 99% of the buying public who don’t look too closely.
Old Oct 31, 2020 | 08:42 PM
GearheadJoe
Well, my theory was that the entire VIN derivative had been sanded off and replaced with a new stamping, while leaving the engine assembly stamping intact.
However, John Hinckley's comment about the "1" in the engine assembly stamping casts doubt on the originality of the engine assembly stamping too. Aside from that possible issue, I think the engine assembly stamping looks pretty good.
However, the characters "4," "2," and "5" in the VIN derivative look questionable to me.
BTW, John Hinckley may recognize the original "204" that I posted earlier. They are from the VIN derivative on his car!
