Timing Light
Old Dec 5, 2002 | 09:38 AM
Pierre's Avatar
Pierre
Default Timing Light
I am considering buying a new timing light to work on my '56 . Ideally, I would like a digital light with both the RPM and advance displayed simultaneously.
But I just don't see how such timing light would be able to determine the advance on a point type distributor or, if this type of timing light would work at all on these older distributors.
Any comments?
Pierre Joly.
Old Dec 5, 2002 | 09:48 AM
JohnZ's Avatar
JohnZ
Default Re: Timing Light (Pierre)
Pierre -
Any of them will work just fine with points ignition, including dual points. My 25-year-old old Penske/Craftsman light finally died a couple of years ago and I replaced it with an Actron dial-back light (they make the new Craftsman lights for Sears) - http://www.actron.com/cgi-bin/web_st...d=222473_23168 - works great on all my cars, and the dial-back feature lets you "map" your advance curve and tailor it to your needs without having to add marks to your balancer. Doesn't have a built-in tach, but I use a separate tach/dwell meter anyway :thumbs:
Old Dec 5, 2002 | 10:09 AM
JL66REDCPE's Avatar
JL66REDCPE
C2 of Year Finalist (stock) 2019
Ditto on the Craftsman Dial Back Timimg Light. I recently replaced my Sun with one. Really great for finding out where you really are with initial timing with and without assisted vacuum advance.
john lolli
Old Dec 5, 2002 | 11:01 AM
62fuelie's Avatar
62fuelie
Default Re: Timing Light (JL66REDCPE)
Another ditto. I use exactly the same set up as John with great results.
Old Dec 5, 2002 | 11:51 AM
Pierre's Avatar
Pierre
Thanks to John and everyone else for their responses.
This may be a bit confusing...
I can see how a digital timing light would be able to provide RPM readout on the digital display.
However, the part I am missing is how could the timing light provide, on it's digital display, a reading of the actual ignition advance. The timing light would need to know TDC in order to provide a display reading of the ignition advance. There is nothing on a conventional point system to "trigger" TDC at the timing light.
On a newer computerized ignition system, the ignition computer provides a "trigger point" for TDC and the light can determine advance from there. Older point system don't have that "trigger point", hence the question.
Thanks again, Pierre
Old Dec 6, 2002 | 12:01 PM
JohnZ's Avatar
JohnZ
All the light knows is when it's triggered by the voltage spike in the plug wire it's attached to (it assumes you have it connected to #1); the dial-back circuitry simply compensates in either direction using the zero-point on the dial as base timing. The dial (or LCD) doesn't show you actual advance - it shows what you have "dialed-into" it, and advances or delays the firing of the strobe based on the "dial-in" setting so the index mark on the balancer is visible against the limits of the existing timing tab. You "dial-in" the setting you want, even if those numbers are well beyond those on the tab, and turn the distributor until the index mark on the balancer lines up with the "0" on the tab, and you're in business. Or, if all you can see on the tab is the "0", just turn the dial until the index mark lines up with the "0", and the dial (or LCD) will show you the actual advance. Terrific tool - kinda like a hand-held distributor machine :thumbs:
Old Dec 6, 2002 | 01:53 PM
Denney's Avatar
Denney
Pierre, I bought an INNOVA professional digital timing light that has become one of my favorite toys (for both my TI and standard ignition vehicles). It has all the goodies (and even comes with a remote starter). :cheers:
Old Dec 8, 2002 | 11:34 PM
tuxedo's Avatar
tuxedo
Default Re: Timing Light (JohnZ)
After reading these timing light posts. I am going to upgrade my light. THX
Old Dec 9, 2002 | 02:07 AM
ghostrider20's Avatar
ghostrider20
Default Re: Timing Light (tuxedo)
JohnZ summed it up the best. With the timming light you just "roll" or "click" the button to return the timming mark back to zero. Although the actual timming is not zero it is the only referance point for the light.
An example.
Rev the engine to 2400 RPM and the timing mark is way off the tab scale. So on my light I just hold the advace button down until the line/mark on the ballancer is lined up with the zero mark on the timing tab. Then I look at the display on the timing light and read the number of advance. The light itself does not know the advance, you are just changing the strobe timing. And this is reflected in the digital read out. Very simple to use. I have a reset button on my light to zero it out in one push, it also has an RPM read out. You need something to read RPM to map out the dist. Someone in the car or a dwell meter. I would recomend a light with the rpm read out if you do not have a dwell meter. I think my light is an INNOVA as well, and was around $100.00. Check E-bay for a better deal.
Mark
Old Dec 9, 2002 | 08:20 AM
Allcoupedup's Avatar
Allcoupedup
I bought the craftsman with the adjustable advance over the weekend. Its on sale + free shipping:
http://www.sears.com/sr/product/summ...id=00921023000
AllcouPedup
Old Dec 10, 2002 | 01:32 AM
SWCDuke's Avatar
SWCDuke
Default Re: Timing Light (Allcoupedup)
Well you sold another one for Sears. My old crock was giving me shocks more often than it was actually flashing the bulb, so I ordered the Craftsman dial back on line, but I'll just pick it up in person as I have to run an errand down their way later in the week. :)
Duke
To Timing Light
