[C2] Seat Heaters ‘64
Old Nov 24, 2020 | 09:14 AM
Classic Car Guy's Avatar
Classic Car Guy
Default Seat Heaters ‘64
I’m planning my next couple installs as I’m resurrecting a ‘64 convertible. I searched but could not find anything on someone installing a seat heater in the old seats. I’m sure there are many of you that thought about it. There must be some of you that actually took the step of installing them. What product did you use? Did you have any electrical issues? Did you also put a heater in the back section of the seat? Seems like a nice idea, and will help keep my wife happy on cold mornings!
Appreciate your responses - thanks!
Drake
Old Nov 24, 2020 | 09:19 AM
rowingone's Avatar
rowingone
https://www.corvettemods.com/rostra-...on-switch.html I would call them but seat heaters are a pretty simple device and the hardest part is getting the seat covers back on after you remove them.
Old Nov 24, 2020 | 09:40 AM
mike coletta's Avatar
mike coletta
Do a search on Amazon for Universal seat heater. There are hundreds of them. Just get the size that you need, and make sure that you install between the foam and the cover, NOT on the metal springs. You can put them in the bottom, and the back. Several models come with some nice switches. I've done a couple of them on spec cars, but we really don't need them in Florida. I think that Al Knoch sells them also.
https://smile.amazon.com/s?k=univers...ref=nb_sb_noss
Old Nov 24, 2020 | 10:54 AM
warrenmj's Avatar
warrenmj
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
Cold mornings in Houston??? 😂😂😂
Just yanking your chain a little as I look outside at a couple inches of snow and 28 degrees in Colorado Springs.
Old Nov 24, 2020 | 04:52 PM
65hihp's Avatar
65hihp
I just can't even conceive of the need for such things, in a 56 year old weekend cars & coffee car. Especially in Houston. The average low temp in Houston is nearly 50.
Even when it very rarely gets down into the 30s, will you really be taking the 64 out in that?
Just curious.
Old Nov 24, 2020 | 05:10 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
I put seat heaters in my 65. They were similar to the ones in the posted links. Two heat levels high and low. I did the bottom and back on both seats. I modified the switching sightly so I could turn on the backrest only or back and bottom. It feels good on a sore back and the seat bottom heat is not necessary all the time. The 65 is a driver and not a car show/cars and coffee car. I use the heaters allot here in Maryland. Go for it.
Tom
Old Nov 24, 2020 | 10:29 PM
RonCL55's Avatar
RonCL55
2025 Restomod of the Year Finalist
2025 C2 of the Year Finalist - Modified
2022 C2 of the Year Finalist - Modified
I agree with Sky65. I changed my seats to Fiero seats but it shouldn’t matter. I put in the following Dorman heaters. They work great and are not very costly. They have a high and low function which is great.
To 65hihp, we here in Southern California are real Weenies. So if the tempature dips below an incomprehensible 60 degrees, I will take my roadster out with the top down but I put the seat heaters on. All is good!
Amazon Amazon
Old Nov 25, 2020 | 01:19 PM
LouieM's Avatar
LouieM
I've had seat heaters in my 67 ragtop for around 15 years. I got one of the no-name sets online and put them in myself, including a second time when I reupholstered the seats in leather. The install is easy with existing seat covers: remove seats from car, cut hog rings and remove covers, lay heating elements on seat bottoms and back, squeeze new hog rings in place, reinstall seats. My heaters are powered by leads from the battery, with relays behind the side panels on either side of the center console. I mounted the two-position switches in unobvious spots on the side panels that I can easily reach while driving. Seat heaters are definitely a neat feature, esp. in cooler weather driving with the top down; SUV inmates look at you bug-eyed as they pass by in uncomprehending mental turmoil.
Hmmm, time to get some spray dye and hit those side panels again.
Old Nov 25, 2020 | 03:48 PM
CorvetteMikeB's Avatar
CorvetteMikeB
This might give you some ideas.
seat heater switch install - CorvetteForum - Chevrolet Corvette ...
https://www.corvetteforum.com/...c2.../4259596-seat-heater-switch-install. html
Old Nov 26, 2020 | 02:24 PM
Classic Car Guy
Just curious.
I doubt I take it out in the 30s, but at night or in the morning it may be chilly and I’d rather keep the wife warm and happy! Heck- I might even turn on the switch once in a while!
Old Nov 26, 2020 | 02:34 PM
Classic Car Guy
Really appreciate everyone’s response to this thread! I’ll plan on buying the heat seaters and going for it! Many thanks and happy Thanksgiving!
Old Nov 26, 2020 | 06:14 PM
RonCL55's Avatar
RonCL55
I think the various switch installations look great. I did something much more simple. I simply put each switch in the gap between the seat bottom and the arm rest. Here is the picture of the drivers side. It is hard to make out the switch in the picture —it is in the seat gap to the left of the top cup holder. It works fine for me and really is not noticeable unless you are looking for it—which I like.
Old Nov 26, 2020 | 06:47 PM
Rusty60's Avatar
Rusty60
although not a corvette i have added them to both beetles i have built. (will also be in the corvette i am working on now as well)
i think i used the same as everyone else just the generic ones that can be trimmed to size..
as others have said i think the placement is key to keeping them inconspicuous.
i love them
To Seat Heaters ‘64
