[C2] Removing 63 Cookie Sheets???
Old Nov 24, 2020 | 08:01 PM
mblake101's Avatar
mblake101
Default Removing 63 Cookie Sheets???
Hello All - I am wanting to remove my cookie sheets without taking the risk of removing the hood. The lower two speed nuts by the radiator core support are very hard to access. I even removed the hood support rod to try to maximize angle and access, but to no avail. Soooooooo, anyone know of a technique or a tool that could possibly help accomplish this quest??? Thanks!
Old Nov 24, 2020 | 08:22 PM
silver837's Avatar
silver837
I have just used a socket and extension (1/4* drive). Are the sheets loose?
Old Nov 24, 2020 | 09:13 PM
mblake101's Avatar
mblake101
Hey Silver837 - I’ve got all the other speed nuts off, but can’t get the angle to loosen the two lowest ones.
Old Nov 24, 2020 | 10:45 PM
silver837's Avatar
silver837
Could you show a picture of it?
Old Nov 24, 2020 | 11:34 PM
mblake101's Avatar
mblake101
You bet, Sir. I very much appreciate your attempt to help. As I noted in your earlier email, you have a 1/4” set. That could be my problem with me attempting removal with a 3/8” drive set. I’m running to Harbor Freight first thing tomorrow morning and get some 1/4” stuff. I post a photo before noon tomorrow, and thanks again for assistance!!! PS - I just saw that you have a Sebring Silver 63 Coupe as well.......COOL!
Old Nov 25, 2020 | 01:13 AM
silver837's Avatar
silver837
Yes this is one of those situations where the right tool for the job is essential .
Old Nov 25, 2020 | 06:23 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
All you need
Old Nov 25, 2020 | 01:19 PM
silver837's Avatar
silver837
Those look great Frank. Where did you get them ?
Old Nov 25, 2020 | 01:23 PM
63driver's Avatar
63driver
Amazon....
Amazon Amazon
Old Nov 25, 2020 | 03:06 PM
silver837's Avatar
silver837
Thanks 63 Driver. I just ordered them.
Old Nov 25, 2020 | 05:32 PM
Six7390gt's Avatar
Six7390gt
2021 C5 of the Year Finalist - Unmodified
St. Jude Donor '25
Originally Posted by Frankie the Fink
All you need
That's a nice set of tools to have around. I bought that set a few years back to adjust and synch the 6 carbs on my Valkyrie, but have used them several times since then in tight spots.
Old Nov 25, 2020 | 08:53 PM
mblake101's Avatar
mblake101
Well, I didn’t know momma had pre-holiday assignments for today, so it took me awhile to get to Harbor Freight. I was able to set some 1/4” sockets and was successful in removing the lower inside one. I tried a HF version of Frankie’s wheel drivers and also a thin flex-head ratchet, but still the angle is too great to place the socket over the lower outside speed nut....thInking of locating a shallow depth 1/4” drive, 3/8” socket somewhere...I’ll do anything to avoid talking a chance to remove the hood off a car that just returned from 3 years in the paint shop...
Old Nov 26, 2020 | 12:29 AM
silver837's Avatar
silver837
Glad to see you are making progress. Is this the first time the sheets have been removed ?
If it is there is an adhesive between them and the hood surface that you will have to overcome.
Old Nov 26, 2020 | 09:24 AM
mblake101's Avatar
mblake101
After repaint, no adhesive. Just trying to close a very small gap at the front by moving the sheet forward as much as possible so that the rear of the sheet drops into the rear recess as much as possible. I had to buy a repop hood since the PO installed a 67 stinger hood.......crazy! I guess the repop may or may not have accurate 63 recesses???
Old Nov 26, 2020 | 09:39 AM
MikeM's Avatar
MikeM
One of those left side front studs should be trimmed off with no nut on it.
Old Nov 26, 2020 | 10:57 AM
vettsplit 63's Avatar
vettsplit 63
From: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
Yep, and you and I know why.
To the OP, you might be able to get a better look at that nut on the stud if you take the hood support loose. The hood will stand straight up if someone holds it while you work on the nut.
Old Nov 26, 2020 | 11:28 AM
mrg's Avatar
mrg
With a helper holding the upright hood steady, use blue tape along the bracket edges to align the bracket location on the hood. Remove the bolts on the side of the hood you're working on. The other side of the hood stays bolted in place. The idea is to pivot the hood slightly upwards to gain a bit of working room without completely removing the hood.
John
Old Nov 27, 2020 | 12:26 AM
mblake101's Avatar
mblake101
Thanks Vettesplit 63. I did remove it, but I’m surprised a little effect it had in opening up the work area. I don’t think my previous 63 was this tight??? I bet my best option now is getting someone over here to help do what mrg suggested. Much less risk as compared to removing the entire hood completely. Thanks for the help!
Old Nov 27, 2020 | 12:27 AM
mblake101's Avatar
mblake101
I think that’s a great option in lieu of completely removing the hood. thanks much! I’ll go get a buddy. Lol,
To Removing 63 Cookie Sheets???
