[C2] GM Block Casting #
Old Nov 28, 2020 | 01:51 PM
Wayne Quade's Avatar
Wayne Quade
4th Gear
Default GM Block Casting #
Looking for any information on GM block with casting # 0-193457 it has a RF prefix on the front of the block. Date code is L90
Old Nov 28, 2020 | 01:52 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
It sounds like you miss read the firing order that’s casted on the intake. The block casting number is on the flange where the bellhousing or trans bolts up
Old Nov 28, 2020 | 01:56 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
I think he's got a prototype small block, based on the "0-" casting number.
To the OP: Can you post a picture of that casting number and an overview picture of the block?
Old Nov 28, 2020 | 04:29 PM
jim lockwood
To the OP: The casting number below is for an aluminum 283. The casting number you posted is later than this but not late enough to be a 4" bore block. Is there any chance your block is made of magnesium?
REX: Due to a disk crash I've lost all the pictures of your magnesium blocks. Can you confirm the OP's casting numbers as being for magnesium?
Old Nov 29, 2020 | 09:28 AM
Wayne Quade
4th Gear
Jim, Do not believe the block is magnesium. Trying to find out what it was originally, like I said it has RF as the last two letters stamped in the front which means it is some type of corvette engine. Trying to find out info for a friend I do not have the block.
Old Nov 29, 2020 | 10:33 AM
jim lockwood
Wayne,
You'll get much better information about that block if you post some pictures. Can your friend make and send you some?
Production engines used the "RF" suffix to signify fuel injection. However with this block having a "0-" casting number, it's not a production engine so you shouldn't read too much into the RF just yet.
Pictures will reveal a lot.
Jim
Old Nov 29, 2020 | 10:14 PM
W Guy's Avatar
W Guy
Jim,
I believe some "0-" parts did make it into production. Rarely but if they passed all criteria, why not use them instead of throwing them away?
Verne
Old Nov 30, 2020 | 07:28 AM
jim lockwood
Originally Posted by W Guy
Jim,
Verne
Verne,
I can imagine seeing some "0-" parts on, say, pilot line cars. Is that the kind of usage you've got in mind?
Jim
Old Nov 30, 2020 | 08:28 AM
AOS_L79's Avatar
AOS_L79
17 years ago someone was wondering the same thing:
http://www.clubhotrod.com/engine-tal...ting-code.html
Old Nov 30, 2020 | 08:49 AM
jim lockwood
Good catch!
Old Nov 30, 2020 | 08:52 AM
W Guy's Avatar
W Guy
Originally Posted by jim lockwood
Verne,
Jim
Yes. Pilot cars would qualify. I also know of several "0-" parts that separately were funneled to racers prior to the final production versions being available to the public. I realize they don't qualify as "production releases".
I've also documented a '64 Pilot car that was actually sold to the public with prototype types parts on it that were never released for production, but that's another story.
Verne
Old Dec 1, 2020 | 02:49 PM
Dr L-88's Avatar
Dr L-88
2025 Corvette of the Year Winner- Modified
2024 C2 of the Year Winner - Modified
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Hi Jim,
I hope you're doing well.
Sorry for the late reply, I just now saw this. These are photos of my NOS magnesium block. As you can see, it carrys the same casting number AND date on the drivers side as do the the aluminum blocks. However, the mag blocks have a second casting number on the passenger side. I'm not sure why GM didnt change the casting date for the mag blocks. I do have authentic documents from the GM archives confirming Oct. 1962 shipments of aluminum blocks and heads and mag blocks to Mickey Thompson. I suspect this was in preparation for his 1963 Indy 500 cars.
I also have another mag block with the same casting number on the passenger side, but the driver side number was ground off and Mickey Thompson stamped in its place. Mickey Thompson is also stamped on the front of the block.
I "suspect" but cannot say with 100% certainty this block was used in one of Mickey's Indy cars.
To GM Block Casting #
