[C2] Universal bind issue
As long as there's no binding when the car is on the road, and you're not flying over the hills with the wheels leaving the road, I wouldn't worry about it. As Avispa says above, a picture would likely help with diagnosing the problem.
Ron
Over travel due to modern shocks is also why you shouldn't run a car with the rear suspended in the air with the wheels at full extension.
63 Vette Rear End Off The Floor, Suspension Hanging. My Apologies for the delay.
AVISPA and Ron, I hope this photo helps. I believe you may be able to see how the driver's spring end sits lower than the passenger side.
Powershift, it measurement is 15 1/4" on the driver's side, 14" on the passenger side.
Rob, if the wheel can't extend far enough to cause the bind during normal driving, then I must have another issue that would cause the differential to self destruct.
Unless its an optical illusion something is going on there, the DS lower leaf spring rubber cushion is much more compressed than the PS cushion....
Also the DS link also has less threads showing under the cushion at the cotter pin than the PS side, they should be very close to even...
Frankie's points are valid as well, but I don't think any of these would account for the total 1 1/4" difference between left and right sides you measure. You mention you replace the one shock after installing the rebuilt half shaft on that side. My bet is that you now have shocks with different amounts of extension on each side. I know you likely replaced the damaged shock with the "same" as originally installed, but I'd still suspect they're not the "same" even though they may be from the same manufacturer and be the "same" make/model. Only by checking the maximum extension of each will you know for certain.
That said, as has been previously mentioned, normal driving won't normally see the wheel being totally unloaded, which should be the only time it would be at full extension. So, from here you can determine how you wish to proceed . . . . . best I can advise you!
PS: Just curious . . . . what brand/model of shocks do you have on the car? Just wondering what the manufacturer's data might show, if any, for the extended length of the shock . . . .
