Valve stem seal replacement - lessons learned
The heads were re-done in 1971, so I was past due!
I used the "pressurize the cylinder" method to hold the valves in place while you remove the springs.
I used the spark plug adapter from my compression tester to pressurize to 100 psi.
The compression tester was cheap (Harbor Freight), and leaks... so that was a challenge. My compressor could barely keep up with the leaks. I'm not to sure about it's ability to measure compression now, either!
Had to fidget with it all the time to try to slow the leaking.. A better adapter that you could snug with a socket would be much better.
After doing a few, it started to go pretty smoothly... until #5
I was replacing the keepers.. got the first one in.. went to grab the other, and when I looked back, the first keeper was gone!
I looked EVERYWHERE.. spent 30 minutes looking for that bastard... on the ground, in the head, around the motor, could not find it.
Meanwhile, my compressor is cycling about 50% duty cycle to keep up.
Clamped the valve to stop it from falling in and shut off the compressor.
Gave up finding the keeper and decided to try to locate one at any nearby auto parts store..... Yeah right!
Best I could do was NAPA - they said they would try to get it on an afternoon delivery from their regional warehouse, but it would likely be tomorrow. (they were right - it never arrived)
Went back one last time to look and FOUND THAT SUCKER with a magnetic stick -- hidden in the frame rail on the passenger side!
So morals of the story: Use a quality adapter to pressurize the cylinder, and have a few spare valve keepers handy (they are .79 cents at NAPA, but not in stock!!!)
After reading some threads here, I went with the Viton umbrella seals (ebay, $18 for a set). Should be a big improvement as the old O-ring seals were either gone, or petrified.
Fred
Fred
Fred
I just replaced the seals on my '67 small block. It solved three problems I was having: 1) smoke on start up, 3) plug fouling on #2 and #4 cylinders, and 3) erratic idle. I had chased the idling problem for some time thinking it was a vacuum leak or carb issue. I found the old umbrella seals were rock hard with 4-5 of them having disintegrated completely.
I'm sure your engine is running much better now!
Alex
I did replace the stock seals (using Felpro O-rings).
But I also installed Viton umbrella seals.. Like these: (photo removed because these were the WRONG type seals! - see posy #22
I had read there is really no need for both... but what the heck.. they don't interfere with each other.
The only issue I was having is some oil consumption (1 qt/1000 miles).. No smoking, but I run synthetic oil, which smokes less than dino.
I noticed a burnt oil smell on deceleration.. I'm thinking it was pulling the oil past the old seals under max vacuum.
We will see!
Fred
My oil consumption problem is dramatically improved. I have put about 500 miles on the car, and it hasn't budged from the "FULL" mark on the dipstick.
Also, the burnt oil smell on deceleration is no longer noticeable.
Fred
There are risks with both methods. You could forget to remove the rope and rotate the engine...ugh. You could lose pressure and have a valve drop with the air pressure method. If you start with #1 at TDC and do both valves, you then rotate the engine 90 degrees and do the next cylinder in the firing order, continuing trough the entire firing order turning the engine 1 3/4 times. As some will discover, at 100psi the air pressure can rotate the engine if you leave it in neutral messing up your plan!
Steve
Did you read my article on Valve seal replacement? I list FelPro umbrella seals which should be used instead of 'positive seals".
The ones shown look like the type you have to machine- the valve guide boss.
Joe
I used these: https://www.ebay.com/itm/143344502636
They are "positive seals", but I did not machine anything.. They slid all the way over the valve guide.
Well.... "easily" is a relative term.. There was slight resistance, even with an oily surface... but no struggle to get them on. Snug, I would say.
So would they act as umbrella seals if they are moving with the valve? Seems like the same shape and size?
