1967 435 corvette
Old Dec 27, 2020 | 04:22 PM
DrJames's Avatar
DrJames
Default 1967 435 corvette
Question , what fuel octane will a 1967 435 corvette run on . 91 I hope? when I was a kid My mom had a dodge with a 426 hemi and it pinged all the time from cheap gas . Found a nice car and before I get into the deal want to really know if it will run on pump gas ..thanks James
Old Dec 27, 2020 | 07:37 PM
macguyver's Avatar
macguyver
Run the 91 ethanol free- some stations have 93 also
You can probably retard the timing a degree or two to help I think
Old Dec 27, 2020 | 07:54 PM
DrJames's Avatar
DrJames
Macguyven thanks this helps and Happy Hoildays to you .
Old Dec 27, 2020 | 07:56 PM
macguyver's Avatar
macguyver
I had a Big Block Chevelle that I ran 91 in no trouble- but it wasnt the LS-6
Old Dec 27, 2020 | 09:39 PM
SBR's Avatar
SBR
It depends on whether the 435 is stock. A 426 Hemi had 10.25 compression and the L71 has 11 to 1 compression. 91 may be a bit low but I would ask the seller the specs on the motor. Retarding the timing a bit may help as mentioned or the use of octane booster could help too. A 67 435 Corvette is great car that you will enjoy.
Old Dec 28, 2020 | 10:04 AM
Trapper Sean's Avatar
Trapper Sean
I would recommend about 12 oz per tank Zaino with every fill up. Fuel will slide through the carburetor with less friction and later you can devarnish your valve stems with just a California duster.
Old Jan 1, 2021 | 01:21 PM
Lotsacubes's Avatar
Lotsacubes
You really need to move over to the C1/C2 forum and connect with those gurus if you haven’t already. The depth of experience there on all things C2 is incomparable. Answers here aren’t wrong, but in the C1/C2 forum many L71 owners will reply. Mine’s a high compression L72 and I’ve never used an additive, but run premium non-ethanol. Best wishes. Hope to see you over in the C1/C2 forum. AND I’ve found only Advanced Search here is worth a flip.
Old Jan 1, 2021 | 02:08 PM
macguyver's Avatar
macguyver
DRJames
The fella that replied just prior to the previous last post was being a A-- clown- his comment was just being a smart alec two year old-
Zaino is a paint protectant
Old Jan 2, 2021 | 12:45 AM
DrJames's Avatar
DrJames
Yes I am not that lame, been around the block many times . I love this forum most guys on here are very helpful . Just never had a bb corvette , so wanted to be sure it would run on pump gas . Asked the seller and he said that it runs just fine on pump gas . Going to have car inspected , as its on the east coast ,I am on the west coast . It scored 96.6 on a top flight , he sent the car to f40 motorsports in Connecticut to fix the problems as that's were the car is Hope all goes well I want to drive it .Thanks for the e-mail and Happy Newyear to you .
Old Jan 4, 2021 | 01:49 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Moved you here not exactly a Detail or Wax question
Old Jan 4, 2021 | 02:30 PM
ettev's Avatar
ettev
If the engine (heads) are unmolested originals you may consider a lead substitute additive too along with at least 91 octane.
Old Jan 4, 2021 | 02:54 PM
Vet65te's Avatar
Vet65te
PM Sent
Old Jan 4, 2021 | 03:11 PM
Tom Austin's Avatar
Tom Austin
Without pics, this car simply does not exist!!! 😃
Old Jan 4, 2021 | 03:41 PM
DrJames's Avatar
DrJames
Reply sent thanks
Old Jan 4, 2021 | 03:59 PM
66WES's Avatar
66WES
VP Fuels Octanium Booster
To 1967 435 corvette
