65 396 TI Harness Support Method?
Old Jan 15, 2021 | 10:01 AM
tdcruzer's Avatar
tdcruzer
Default 65 396 TI Harness Support Method?
Looking for some guidance on installing a TI harness from the radiator support, on the passenger side,with relation to the overflow hose coming from the radiator to the fill tank.
Unless I am missing something, the AIM shows the routing of the harness along the fender-well on the passenger side just as the engine and lighting harness would be installed on the driver's side. I don't see a configuration / installation showing the harness and the overflow hose together, as they take the same path along the passenger's fender-well.
Do they use the same straps (3 places) or do they use 1 strap for each (2 straps each at 3 places)?
The car is an original TI car, but when I removed the Amplifier it was tucked up on the forward face of the driver's side fender well, and the harness ran with the engine & headlight harnesses along the driver's side fender-well
Thank you for your time
Old Jan 18, 2021 | 12:04 PM
tdcruzer's Avatar
tdcruzer
I installed the harness wire behind the overflow hose along the passenger side. Looks good to me, can't really see it except for where it travels to the amplifier in the front and goes by the fill tank heading for the firewall.
Old Jan 18, 2021 | 04:11 PM
DansYellow66's Avatar
DansYellow66
Have you looked in an AIM for your model year? It usually shows details like this.
Old Jan 19, 2021 | 12:16 PM
tdcruzer's Avatar
tdcruzer
Yes I have. It only shows the harness, no sign of the overflow hose or the fill tank.
To 65 396 TI Harness Support Method?
