Engine start issues
Old Jan 17, 2021 | 10:23 AM
vette58uk's Avatar
vette58uk
2nd Gear
Default Engine start issues
My car has recently been shipped from the US to the UK. Engine was running fine when delivered. Has sat in a cold garage for 3 months, connected to a trickle charger. Now engine turns over but won’t start. Any advice on trouble shooting steps appreciated. Battery is good. 283 engine with 2 x 4bl carbs.
Old Jan 17, 2021 | 03:26 PM
dplotkin's Avatar
dplotkin
2015 C2 of the Year Finalist
I will assume the carb bowls are dry from nonuse and suggest that with a good strong battery you begin by verifying there is fuel in the tank, the choke is closed (set) and after a few no more than 10 second each crank cycles if it doesn't fire, pull the air filters and peering down the carb pull the throttle back and forth and determine if you are getting fuel from the accelerator pump. Start there and let us know.
Dan
Old Jan 17, 2021 | 04:55 PM
MikeM's Avatar
MikeM
Stick a 12 volt test light on the distributor side of the coil and crank the engine. You should see the test light flashing. If it doesn't flash on/off/on/off, your points are not making contact. Run a point file a couple of strokes through the points and you should be good.
Old Jan 17, 2021 | 07:26 PM
kellsdad's Avatar
kellsdad
I don't disagree with anything said above. Given that the engine ran normally when parked it almost has to be either too little fuel, too much cold air or a new problem with the ignition. I find a quick squirt of starting fluid and seeing the choke set tells me a lot. If it fires briefly but won't continue to run you know the ignition is ok, but it may not be getting fuel. Opening the throttle once while looking down the throat of the carb will reveal if there is fuel available. The other possibility is it became flooded during your earlier attempts to start.
To Engine start issues
