I installed a Spal puller fan inside the shroud in front of the factor fan on my C2 with factory air. The issue is with the fan controller. It is a BB car so there is not a ton of room. I installed Derale PWM controller in attached to the inner fender on the front side adjacent to the head light.
It is a pretty good spot except that it is not accessible with the hood on. I did not anticipate that I would need to get to it. The problem is that the controller seems to have quit after about 2 minutes of running. I looked online and reviews are abysmal. Does anyone know of another controller that is small as the Derale that works?
