[C2] TI Distributor disassembly
I actually did find that site through other threads regarding distributors on the forum. But it does not describe the disassembly procedure, more of a description of the work he will do after disassembly.
RON
P.S. DO NOT remove the screws that hold the pickup coil together. The top plate with the 8 points, coil and bottom plate come out as 1 piece.
PM me with your email address if you would like a copy.
Joe
Joe, I will PM you, thanks.
RON
Check the shaft side play in the housing. If it's more than barely perceptible you might as well have new housing bushings installed now while it's apart.
Duke
Ron, I have removed the plastic connector and pulled the wires through the housing. The stripe was barely noticeable because of age I guess, thanks for pointing that out. The brass washer was indeed nicely stuck to the underside of the pick-up coil.
Duke, the felt under the pick-up is in remarkably good shape compared to everything else, but that seal was very dry and fell apart easily revealing a nice supply of dried up old grease. The end play is excessive, almost .050 and thats including a .030 washer/shim that was already there. I assume the end play can be corrected with additional shims and or is there a maximum to amount of shims?
The biggest issue I found is side play on the shaft, it is very perceptible and I measure .006 on a dial indicator placed about 1 inch from the bottom of the shaft. As per the pic, you can also see that it is scored, very similar to the picture of the shaft on Joe's paper. I measure .4875 at the area where it is scored vs .489 where the shaft is clean. So I assume in addition to the pick-up coil (because of the frayed wire), my needs will also include the mainshaft and a bushing set. At this point, I might as well also order a set of weights and springs and vacuum advance for a full rebuild.
Obviously I do not have a distributor machine in my garage. So the key question is, given that the parts available are more generic and meant to cover many different applications, are there any parts such as weights and springs, or mainshaft (because of cam profile) that I should try to salvage and reuse in order to eliminate the need to need to inspect on a distributor machine? Or is inspection on a machine a must regardless? And if the advance curve is not exactly as per spec for my engine, are there any adjustments that can be made to the distributor?
I guess I need to educate myself a little more on the subject!
Thanks for all your help.
Luke
Last edited by Luke 1967; Feb 17, 2021 at 03:55 PM. Reason: correction on shaft dia. size
The plastic seal for the oil well is still available using the GM part number. About $4-5. I personally used cotton pads cut to the correct OD and ID and saturated with 20w oil. Pads were women's makeup removal square cotton pads, which worked nicely. Needed about 3-4 stacked in the well.
Larry
I recently did some tuning on a '66 L-36, which is basically the same engine with a four barrel instead of the trips. The distributor was really buggered up. The OE VAC was sticky and the centrifugal was limited to only 20 degrees. We did a complete blueprint/overhaul and basically took it back to stock for California's 91 PON premium, and it worked out well after a LONG day including a run out to David Sokolowski's place for parts.
About the only thing you can do to improve it is bring in the centrifugal a little earlier. The OE centrifugal is 32 @ 5000 which is pretty lazy. Depending on what the CR and centrifugal curve are today and your available fuel octane you may be able to make it more aggressive without detonation by using the black-silver-gold springs in that order from the Mr. Gasket 928G spring kit. It's something you can do once it's back in the engine.
What's the number stamped on the rotating pole piece assembly.
You can get a head start on the tuning by searching for threads started by me and downloading and reading the tuning seminar... also the L-79 distributor blueprint/overhaul thread. The TI and single point are basically the same... just some parts swaps. The base for both is identical to you can easily convert one to another either way.
Duke
In answer to your questions, the number stamped on the pole piece is 734 . However, the number on the distributor tag is 1111093 which I believe is original to 66 425HP, not L68. Not sure how that will impact the centrifugal curve. I usually run Shell V-Power 91 premium with no detonation issues. I also have access to 94 Octane but it contains ethanol, so I limit its use to long drives when I know I will use up the whole tank.
Luke
Yes, and ...093 distributor would be for the '66 L-72. The max centrifugal spec is 30 @ 5000 and the OE VAC is stamped 360 12, start @ 6", 12 deg. (crank) @ 12". What's the ID on your VAC and start and stop points in Hg"
Duke
Based on the input and what I've read so far, my plan is to salvage the (what I assume to be) original mainshaft and cam for the distributor I have, and replace everything else including the lower bushing (upper bushing seems ok, virtually no side play). I will order new weights (I will keep the old weights as back-up just in case), and the Mr Gasket 928G Spring set in order to improve on the OE centrifugal. I'm assuming I should order the 360 VAC unit.
Let me know I'm heading in the right direction or missing something. Thanks
Luke
Use a Mighty-Vac to see when the vacuum can begins to pull in and when it is all in. Easy to do and will also verify that it still works..........but you may still want to replace it with something better for your car.
Larry
Luke
