powerglide
Old Feb 17, 2021 | 12:02 PM
tombutler's Avatar
tombutler
2nd Gear
Default powerglide
I own a 1963 convertible equipped with a low hp 327 engine. It currently has a muncie 4-speed and I would like to switch it to an automatic trans. I tried a th350 but it would not fit without modifying the exhaust and crossmember to fit. Has anyone made this switch either using an original powerglide or some other automatic trans ? HELP!
Old Feb 17, 2021 | 12:27 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Search about using a 200R4
Old Feb 17, 2021 | 12:29 PM
morly1963's Avatar
morly1963
Try here
https://www.google.com/search?q=puti...hrome&ie=UTF-8
Old Feb 17, 2021 | 04:13 PM
Mr Fufu's Avatar
Mr Fufu
Hi Tom,
The TH350 is a direct swap for a Powerglide. I did this swap in my '67 and the installer didn't have to move the motor to get the TH350 installed. I didn't have to modify the exhaust, and no crossmember mods were needed as the TH350 rear mount is in the same location as the PG mount. Note that the TH350 was introduced in1969 as a 3-speed replacement for the PG, and is nearly identical in length. That meant it was directly compatible with existing PG auto trans mount locations on existing car frames of the day.
Read post #15 in this thread where I explain more about my PG to TH350 swap: https://www.corvetteforum.com/forums...onversion.html
Note the '63 is a slightly different bird with regards to the auto shifter linkage. I believe Shiftworks may still sell a kit to adapt your stock shifter to work with the TH350. Call Herb Gray at Shiftworks - he was very helpful during my swap..
Hope this helps.
Alex
Old Feb 17, 2021 | 09:57 PM
R66's Avatar
R66
There were a couple of different length TH350s. I believe the ones used in trucks were longer. Could it be you have a longer one?
I have 3 PowerGlides and a TH350 in a storage trailer and they are all the same length.
I can see that the exhaust pipes may need to be tweaked to clear the back of the TH350.
I have not done the swap in a C2, so take this as information good or bad.
Old Feb 18, 2021 | 07:36 PM
Mr Fufu's Avatar
Mr Fufu
The TH350 transmission itself is the same length regardless of application. Here are the transmission body lengths and rear mount position of the more popular GM automatics:
Three different tail shaft lengths (6", 9", and 12") are used to adapt the TH350 transmission to the vehicle its being installed in. Powerglides used 2 different tail shafts, 6" and 9".
The tail shafts are interchangeable and can be removed without distributing the main transmission body.
This drawing summarizes this nicely:
As you can see, the Powerglide and the TH350 share the same 22 1/4" length from front of converter housing to rear transmission mount.
A TH350 with a 6" tail shaft is the same overall length as a Powerglide with a 9" tailshaft, as used in the C2 Corvette.
As the overall length of transmission and tail shaft is the same, and the rear mount is in the same position, a TH350 is a direct bolt-in swap for a Powerglide,
Old Feb 19, 2021 | 11:09 AM
R66's Avatar
R66
That's interesting, because I swapped a TH350 into a 64 El Camino that had a factory Powerglide and did not have to shorten the driveshaft. Not saying it should not have been shortened, but never had any problems.
The chart shows the shortest TH350 is 27-5/8" while the shortest PowerGlide is 25-5/16". That 2-5/16" of extra length would appear to require the driveshaft in a C2 (and other cars) to be shortened to do it correctly..
If the chart is correct, the mount is in the same position, and I recall it is.
It very well may require exhaust pipe modifications as the width of the automatic is greater just before the cross member.. Indeed, checking one of the supporters sites show different pipes for the manual and automatic.
Old Feb 19, 2021 | 11:33 AM
tombutler's Avatar
tombutler
2nd Gear
Thanks, Very helpful.
Old Feb 24, 2021 | 06:40 PM
Mr Fufu's Avatar
Mr Fufu
I swapped a TH350 with 6" tail shaft directly into my '67 with no modifications or cutting of the driveshaft required. That's one of the advantages of this swap.
I didn't have to modify the exhaust pipes either. The left side head pipe is closer to the trans pan than it was with the Powerglide, but this hasn't caused any issues.
Here's a picture after the swap, showing the location of the TH350 trans pan in relation to the head pipes.
The tight fit between the left head pipe and the transmission pan hasn't caused any problems. I've used an IR gun to check the pan temperature and it never exceeds 200F even in hot weather, idling in traffic.
Old Feb 24, 2021 | 09:25 PM
R66's Avatar
R66
Exactly what the OP needed.
As I recall, the PowerGlide has a sqare pan so I am surprised the TH350 was a tighter fit, but I don't know the dimensions of either.
To powerglide
