C2 engine location
Old Feb 24, 2021 | 08:40 PM
Dr L-88's Avatar
Dr L-88
2025 Corvette of the Year Winner- Modified
2024 C2 of the Year Winner - Modified
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Default C2 engine location
I have an 63 ex drag car that I am restoring. The car was last raced in 2016 and the engine was installled using front and rear motor plates. The frame mount towers had been cut out. I want to install the towers again so I can use stock motor mounts. The frame bracket for the clutch Z bar had also been removed since the car was raced with an automatic transmission. I'm looking for recommendations to get the small block engine mounted in the proper location. I will have to weld new frame tower mounts and the clutch bracket on the frame and I want to make certain they are in the correct location.
Thanks for your help.
Rex
Old Feb 24, 2021 | 10:06 PM
TCracingCA's Avatar
TCracingCA
I have one old drawing of just the frame, with all kinds of measurements. I will get that out to see if it has those dimensions, as it is in a general notebook that I dont have stored away.
Old Feb 24, 2021 | 10:33 PM
MrTrim's Avatar
MrTrim
found this on the web. Looks like the motor mount brackets are 23 3/4” at the front edge to the front frame horn.
hope this helps.
Chris
jrm5657's Avatar
jrm5657
2022 C2 of the Year Finalist - Modified
Rex,
If the transmission crossmember has not been removed or modified, I would mock up an engine and transmission assembly and position it in place using the transmission mount to work from. I have a 65 frame sitting in the shop that I could take some dimensions from, just give me a call, you have my number.
Jim
Old Feb 24, 2021 | 10:50 PM
Dr L-88's Avatar
Dr L-88
Originally Posted by jrm5657
Rex,
Jim
Thanks Jim, but the crossmember has been highly modified.
Old Feb 25, 2021 | 01:11 AM
silver837's Avatar
silver837
It might be easier to get a new frame ?
Old Feb 25, 2021 | 03:38 AM
tuxnharley's Avatar
tuxnharley
Do I remember correctly that the engine in a C2 is actually offset slightly from the center line?
Old Feb 25, 2021 | 05:41 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
yes off set towards the passenger side
Old Feb 25, 2021 | 06:27 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
That is my understanding from an old JohnZ posr, the driveline is indeed offset and for good reason:
https://www.corvetteforum.com/forums...post1589220467
Old Feb 25, 2021 | 07:19 AM
kellsdad's Avatar
kellsdad
If you are trying to precisely replicate the original engine mounts, I can't help. But if not, I agree with JRM5657's suggestion. When I built my Cheetah tribute I mocked up the entire drivetrain to get clearances and driveshaft angles right and then tack welded the motor mounts where they needed to be. When everything was out of the way I finished welding them in.
Old Feb 25, 2021 | 07:46 AM
Factoid's Avatar
Factoid
Yep, notice in the diagram posted above that the driver side engine frame mount is longer than the passenger side. When those frame mounts are purchased welding them into the correct position will provide the proper engine offset.
Old Feb 25, 2021 | 07:51 AM
Jaguarmaven's Avatar
Jaguarmaven
Maybe you can find a used one of these from someone that no longer needs it...made of poly foam
Here's the link to the Summit catalog
P-Ayr Products Replica Short Block Engines 2021
Dan
Old Feb 25, 2021 | 08:30 AM
Frankie the Fink
Army
Dan
And they're much easier to restamp.
Old Feb 25, 2021 | 10:56 AM
joewill's Avatar
joewill
hope this helps.
Chris
That's a C3 frame. The Tail is different and I think the front horns are different. I expect the C2 dimensions are at or very near these specs, but I would find a 63 frame drawing to be absolutely sure. I think there is a 63 drawing out in the internet also somewhere.
Old Feb 25, 2021 | 12:25 PM
LouieM's Avatar
LouieM
I've also wondered why Corvette engines are offset. I learned a new word from JohnZ's write-up: Brinnell
Old Feb 25, 2021 | 01:58 PM
MikeM's Avatar
MikeM
It is true that you don't want a perfectly straight driveline due to what was mentioned.
It is also true that all the mid/late (and later) '60's Chevrolet car lines excluding Corvair and possibly Impala, had the engine, transmission offset to the right and that was to give more room for the pedals in the driver's foot well.
Old Feb 25, 2021 | 02:06 PM
MikeM's Avatar
MikeM
Unless I'm missing something on that frame drawing, I don't see much advantage in using it to locate the engine. Don't see dimensions to key reference points, especially height.
I believe if I was doing the work, I'd eyeball it like this. Determine the height of the crank center line above the front crossmember, the height of the transmission in the linkage opening and the location of the shifter handle relative to the opening. Easily measured off other Corvettes.
Mock up the engine/transmission, shifter to match those measurements. Weld in a new, production transmission crossmember to hold those dimensions and then move to the front. Attaching the new motor mounts brackets to the engine, the free end should fall in place on the frame in the right relative location. That is, as long as something isn't reefed out of shape.
Old Feb 26, 2021 | 02:01 AM
TCracingCA's Avatar
TCracingCA
Same picture as above.
Old Feb 26, 2021 | 02:05 AM
TCracingCA's Avatar
TCracingCA
Check the frame to make sure it is square. Draw a line at those dimensions and mock an engine up with mounts attached, and set those bracket down on the line. So the tilt? I would probably put the tranny crossmember in first. That should be level to the frame. I would put a bolt-in in. I think the offset is in the brackets (length and configuration of each), but never studied that on my cars. Do you have the brackets yet on hand?
To C2 engine location
