shifter decision
Old Apr 10, 2021 | 12:00 PM
66427-450's Avatar
66427-450
Originally Posted by bfitz241
allow me to ask a pointed question re: the stock shifter then,
How defined are the gates? How precise is the pattern?..... have no experience with C2 original style shifters. Thanks
A well-maintained and adjusted original, or a true-to-spec reproduction, is as smooth as silk if you ask me, and a pleasure to use, both during high performance driving, and normal street cruising. I’ve had numerous Muncie equip cars with Hurst shifters through the years, yes the pattern may be a bit narrower, apparent when your power shifting between second and third, but for anything less than full throttle drag racing i’d certainly go with the factory shifter. But you really have to drive both yourself to form your own opinion.
Old Apr 10, 2021 | 02:48 PM
MikeM's Avatar
MikeM
Best answer.
Old Apr 10, 2021 | 03:13 PM
68hemi's Avatar
68hemi
C1 of Year Finalist (performance mods) 2019
I have not seen any mention of the factory shifter in the optional short throw position? I don’t recall how many years they came this way but my 65 has the option and I have it in the short throw position and I love it.
Old Apr 10, 2021 | 04:18 PM
66427-450's Avatar
66427-450
Originally Posted by 68hemi
I have not seen any mention of the factory shifter in the optional short throw position? ......
see post #20
Old Apr 11, 2021 | 09:12 AM
59BlueSilver's Avatar
59BlueSilver
2023 Restomod of the Year Finalist
Originally Posted by jim lockwood
I completely disagree.
The repro shifter in my '60, now 30+ years old, is still smooth and precise. No issues with it at all.
My bride's Grand Sport track car also has a repro shifter. It, too, is smooth and precise. It has a reassuring feel when upshifting on the straights or dowshifting for a turn.
In contrast, my Grand Sport vintage racer has a Hurst with the look-alike stock handle. (Yes, I drank the Kool-Aid....once) Even after thousands of track miles involving multiple shifts per lap, the dang thing is still stiff and notchy. Bearable but definitely not as pleasant as the stock shifter in my bride's car.
That is exactly what I experienced! Love my stock repro shifter.
Old Apr 12, 2021 | 08:50 AM
phil2302's Avatar
phil2302
If you like a day 2 car look go with the Hurst however a properly installed and fully adjusted stock shifter is AOK in my book. Never had any issues with the ones I have had.
Old Apr 12, 2021 | 03:22 PM
rcbach's Avatar
rcbach
3rd Gear
In terms of pure shifter feel and precision, you can't beat Hurst. Night and day over Muncie. But if you want originality, find a good used OEM and re-build it. The reproductions get sloppy real fast.
Old Apr 12, 2021 | 05:04 PM
mrg's Avatar
mrg
The factory shifter in my ‘64 worked ok, but was a bit on the sloppy side. SS shims were used to beef up spring clip load on the shift rod ends. A shim was placed in the main housing to tighten up clearance between the shifter fingers.
Along with a good clean and lube the factory shifter works smooth as butter now. I’m happy with it.
John
Old Apr 12, 2021 | 05:58 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
I've been waiting 30+ years for my repop shifter to become sloppy. How much longer do I need to wait?
Old Apr 12, 2021 | 11:16 PM
59BlueSilver
Couldn’t get rid of my Hurst fast enough in favor of a stock repro. Love it!
Old Apr 13, 2021 | 05:43 AM
VITIV Coupe's Avatar
VITIV Coupe
I have a 64 327/ m-21 and when I pulled the trans to replace all the gaskets and put it back in the car, I set up my original 4 speed muncie shifter per shop manual instructions and I couldn't be happier, smooth as silk. Sorry about the pictures quality.
Old Apr 13, 2021 | 10:39 AM
68sixspeed's Avatar
68sixspeed
St. Jude 15 Year Donor
St. Jude Donor '10 thru '26
As mentioned in post 21, best advise, it is personal preference, see if you can find someone near you to let you feel a hurst and another stock one to compare to yours. While a lot of us won't let someone just hop in and drive our car, I've never said "no" to someone at a car show etc wanting to sit in it etc, and explaining the situation you should be able to push the clutch in and get some idea of the hurst vs stock. I thought my 62's shifter was worn out when I got it until another c1 owner let me feel what his car was like, nope, that's just how they feel. Some people love them, some don't. Personally I like the hurst feel (the hard stops, spring bias side/side) from the days of driving a 4 speed in a 68 camaro, but I have stock shifters in my 62 and 72, and I'm putting the stock one back in my 63 now just to keep things original.
Old Apr 13, 2021 | 01:03 PM
  #33
ghostrider20's Avatar
ghostrider20
This has been my experience. I have the stock shifter. I think it is smooth. He Hurst feels stiff and chunky.
Old Apr 13, 2021 | 01:08 PM
  #34
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Heres the Hurst @ Summit https://www.summitracing.com/parts/huu-3915405
They still make this model and rebuild kits.
