Help requested for ‘66 rag joint replacement
I need to replace my torn rag joint, but can’t find the answers in extensive forum searches & am hoping someone can offer advice.
It’s a ‘66 sting ray, telescoping column, no power steering. But, the steering box is right against that header, so I’d rather not unbolt & try moving either of those, nor do I want to go loosening the entire steering column @ the firewall, just so I can spread apart the steering column shafts enough to remove/replace the entire rag joint assembly.
Which leaves me (I think) 2 options; replace just the rag disc, or preferably, replace the front coupler half with a preassembled & riveted one like this from Lares;
My questions are; is there usually enough space between the ends of each steering column shaft to slip out the entire front coupler half, & enough space to reinsert this Lares unit? I am doubtful that there’s enough space.
And if there isn’t enough space, I’ll need to remove all 4 rivets/posts & install a new rag disc kit, like this one from Zip Corvette.
Or is there a better rag kit with 4 threaded mount rivets/posts that’ll install correctly with the stock ‘66 front & rear coupler halves? I know 4 threaded posts/nuts isn’t optimal, but I’ll chassis paint-mark & red loctite those nuts & be rechecking them regularly.
Last question, is it advisable to use a small angle grinder to grind off those 4 stock rivet heads..am I missing a better removal option?
I don’t have an air hammer, & cant get a bench press down in there, so I’m hoping someone’s been down this road & can say if there’s enough space for that Lares unit, or not, & if not, is that Zip kit a decent choice that’ll work with my stock coupler halves?
Cost isn’t the issue, I’d just prefer not to unbolt headers just so I can unbolt the steering box, or unbolt the entire steering column at the firewall. I also hope to order the right part the first time. And thanks for reading all this & for any advice..& sorry for writing War & Peace here, just trying to be clear & precise.
ZIP does have replacement parts, but I guess they won't pass NCRS muster. They look perfectly serviceable to me, though.
Ray
