Hinge Cleanup
Old Apr 13, 2021 | 10:48 AM
jc03's Avatar
jc03
Default Hinge Cleanup
Hello. I think at some point my 66s engine bay got a spray can treatment and 55 years of grime. It’s a St Louis car so I think it would be correct for the hood hinges/catches to have some overspray. I don’t want to overrestore them. Would you leave as is or clean up with some paint thinner? I do like the gray look of fresh ones. Is there any concern in taking the original finish off if I do use thinner? I plan on leaving them on the car so I don’t screw up any alignment.
Old Apr 13, 2021 | 11:40 AM
rowingone's Avatar
rowingone
from 66 NCRS " the hinges, shims and bolts typically appear black from the blackout process, however many show slight body color on the outboard edge of the hinges, and outboard areas of the fiberglass adjacent to the hinges"
