No brake lights
problem. The brake lights don't come on when depressing the pedal and the red brake light on the dash panel flashes on and off
constantly. Now I haven't bled the brakes and haven't put in the master cylinder because wanted to make sure every thing under
the dash was ok. Since putting in this new booster my radio quit working. It lights up but won't play. It is an aftermarket radio.
All help is greatly appreciated.
Butch
S. Jersey
Butch
S. Jersey
For your brake lights not working, it sounds like you may have pulled the white wire that goes from the brake light switch up to the turn signal switch out of the connector on the steering column. You also have a brake light fuse in the fuse panel and your brake switch could be disconnected or defective. If you have or know someone who can use a volt meter on the switch and fuse box, you should find that very quickly.
Thank you 65GGvert. I'll check it out tomorrow. You guys amaze me!!
Butch
S. Jersey
