front spindles
Old Apr 20, 2021 | 09:56 PM
bauto's Avatar
bauto
Default front spindles
are all the front spindles the same from 63-67
Old Apr 20, 2021 | 10:19 PM
gleninsandiego's Avatar
gleninsandiego
Not sure about the others but I had to change out the spindles on my 63
when I went to front disc brakes
Old Apr 20, 2021 | 10:33 PM
FLYNAVY30's Avatar
FLYNAVY30
63-64 are different from 65-67. I believe the C3 spindles (68-later?) were similar but beefier than the 65-67 disc brake spindles.
Old Apr 22, 2021 | 10:58 AM
GENEN52's Avatar
GENEN52
The C2/C3 Corvettes used three spindle types.
The 63-65 drum brake
The 65-68 disc with small wheel bearings
The 69 up with larger wheel bearings
Old Apr 22, 2021 | 12:17 PM
Avispa's Avatar
Avispa
All of that, and the 69 up with larger wheel bearings use larger diameter bolts for the caliper brackets and steering arms.
Old Apr 22, 2021 | 12:29 PM
Factoid's Avatar
Factoid
The 63-64 drum brake
Made a slight tweak to this as drums were only 63-64.
Old Apr 22, 2021 | 01:17 PM
GENEN52's Avatar
GENEN52
Actually drums were available to order as a credit option in 65 as long as there were leftover sets from 64 still in the factory.
To front spindles
