[C1] Key for center console
I have a 61 with a new custom interior done by Kindigs guy Jason. While it was in Salt lake they apparently lost the keys. They replaced the key locks so that now one key does the ignition, doors and trunk. It does not however do the vertical center console between the seats.I want to be able to lock it so i need a key that works. Do I need to remove the push button lock and take to a lock smith or is there another way to do this. If I do need to remove the lock assembly how do i do that? Jerry
Jerry, this should help you. I think a locksmith is your best option.
https://www.corvetteforum.com/forums...er-removal.pdf
jerry gollnick (04-30-2021)
