Heat Riser
Old May 12, 2021 | 10:42 AM
Spowell637's Avatar
Spowell637
Default Heat Riser
Could someone please explain how wire the heat riser open on a 67 C2 coupe L79? I will be working underneath the car on jackstands.
Thanks in advance
Old May 12, 2021 | 11:04 AM
dcamick's Avatar
dcamick
2019 C1 of Year Finalist (appearance mods)
Just make curtain that it pivots open and closed freely. When heated, the external spring heats and weakens causing the external counterweight to drop opening the internal plate to let exhaust freely flow through the side or under exhaust system. Be sure to check for free movement (pivoting). If seized close, noticable performance issues will prevail..... Trust me!
Mine was relatively seized. I bought a spacer and removed mine on my 65 Coupe. If removed, this WILL create a "Worming up" Issue in colder climates.
Others will chime in...........
Old May 12, 2021 | 11:26 AM
silver837's Avatar
silver837
The spacer is used on the FI engines as they do not use a heat riser. They are avalable from most of the venders.
Old May 12, 2021 | 11:48 AM
SWCDuke's Avatar
SWCDuke
Thanks in advance
1. Procure 2-3 feet of stainless steel safety wire.
2. On a cold engine move move counterweight 90 degrees to the open position.
3. Wrap two turns of wire around counterweight and manifold in such a way to hold the valve open.
Duke
Old May 12, 2021 | 01:15 PM
polo91's Avatar
polo91
Get rid of the heat riser, even when open it is an obstruction in the exhaust flow. If you want it to look stock, get someone to cut the baffle out and leave the weight and spring in place.
Old May 12, 2021 | 01:33 PM
65GGvert's Avatar
65GGvert
Pull it down as far as it goes (not quite straight down) and tie it down with wire. That's the quick inexpensive way to eliminate the riser function. If you like the way it goes without it, you can always remove it and replace it with the spacer.
Old May 12, 2021 | 05:11 PM
Tooth Doctor's Avatar
Tooth Doctor
I took out the internal flapper valve and shaft, weight, spring, etc. then welded the shaft hole closed.
Old May 13, 2021 | 12:06 PM
John BX NY's Avatar
John BX NY
Easier to just wire it open as described. Did it ten years ago. Easier hot starts due to less fuel percolation in the carb bowls and no popping sounds out of the RH exhaust manifold are the expected benefits. Choke may take longer to kick off in very cold weather but I dont drive it in the winter.
Old May 14, 2021 | 10:42 AM
Spowell637's Avatar
Spowell637
thanks so much for your reply. Where would be the best place to tie it off?
Thanks again
Old May 14, 2021 | 12:37 PM
Tooth Doctor
Open the flap with your hand, then wrap wire around the weight and the exhaust pipe to hold it open.
To Heat Riser
