Alternator Options
Old May 12, 2021 | 09:25 PM
Yellow6t7's Avatar
Yellow6t7
Default Alternator Options
67 Corvette with a 37 amp alternator.
I have spare 42 amp and 55 amp alternators.
Would either or both be OK to use?
Old May 12, 2021 | 09:30 PM
R66's Avatar
R66
YEP, you can even take the internals from the 55 amp and put in the 37 amp if you have the right numbers you want to save. I heard there is also an outfit that can boost the output above 55 amp, but I don't have the info.
Old May 13, 2021 | 01:00 PM
Pilot Dan's Avatar
Pilot Dan
I upgraded my original 37A correct date alternator to 100 Amp myself or you can have it done for you by a local shop. If you are going to do that, map out your current draw (if you have added items) and figure out the maximum load it will draw to see if you need to upgrade the original red wire from the alternator to a heavier gage.
Old May 13, 2021 | 03:59 PM
Yellow6t7's Avatar
Yellow6t7
Thanks for the advice. My 37 amp alternator is original to my car.
Thought I would put it on the shelf and use one of my spares.
Not looking for judging points.
To Alternator Options
