In Julian dating, the first three digits represent the days of the year, and the fourth digit is the year. Julian dating began around 1972-73. Assuming a "0" as the first digit (likely), that would make the date January 27, 1976.
Larry
From: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
Originally Posted by 65 Pro Vette
It is probably a zero not a C that is the Julian calendar date which would be 027 day of 1976,86, or 96.
Fixed! too early today!
they didnt use Julian dating til 72 or 73. That 2818 Holley with the GM part number I think makes it a March 27,1966. And the part # is correct for a 350/327 engine. JMHO
no it can’t be as up until 69 or so Holley only used a three digit date formate. After that it went to four
Ok so the jury is still out on this one?
I believe the zero digit is correct I did not think of that when posting. So it would be a post 1972-73 built carb if I understand all the responses correctly?
TIA,
Marshal
TIA,
Marshal
What is there to argue?? With four digits for the date code, the carb was made after 1973. Julian dating for Holley carbs has first three digits as the day of the year, and the fourth digit as the year.
Saying that, the year could be 1976 or 1986...............but most likely 1976.
My own 1967 car has a similar Holley #3810 service dated carb from 1977. It reads #2587 (day 258 in year 1977).
