60 Corvette up from Florida Not run in a while found the gas tank rusted replaced the tank the lines filter got it running have no throttle response hit the throttle it dies replaced the ballast resistor and coil still have the same problem. When it sits for a long time then when started it will run for 30 to 45 seconds the slowly dies out.
Any thoughts on what to try next ?
Thank you
Check fuel flow rate and fuel pressure at the fuel line inlet to the carb, while cranking the motor, you should ahve about 5 PSIG pressure, and strong pulse flow. If not, your pump is probably bad, or clogged with rust from the tank..
Doug
Thank you
You may have multiple issues to track down. That said, the one symptom of no throttle response is consistent with an inoperative accelerator pump. If the car has been sitting for years, it wouldn't be unusual for the leather seal to have shriveled, dried out, shrunk, etc, and to no longer be functional.
Nothing you have described suggests an ignition problem. Focus on fuel delivery.
had a similar problem with a c-2 FI vet.turns out the chines fuel sending unit pickup tube was incorrectly bent such that the sock was about 1/4 tank of gas in the vet. take a horoscope and see if the tube and sock are above the level of gas in your tank. mike mccagh
Check all rubber hoses from the tank and to the fuel pump. A cracked hose will gravity fill with fuel but it suck air when the pump is drawing a vacuum. Thus, you get fuel to run for a few seconds or minutes before you get air.
Jim has a very good point with the leather accelerator pump.
Put a fuel pressure gauge in the line with a Tee to verify it is a fuel delivery problem. If you can't tee in a gauge, verify the loss of fuel by observing the accelerator pump shot after it dies. Or you can also choke it with a rag or the choke blade as it is dying to see if it will pick up again.
Yep! also, I would not rule out the diaphragm on the fuel pump if it sat with gas. I had one eat away from sitting. It left me on the side of the road.
Oxygenated fuel probably ate up the accel pump that Jim Lockwood was referring to. As someone said, rust didn't stop at the tank. You need to go stem to stern with the fuel delivery system.
