Pulling the carb - straight forward?
- disconnect the fuel line (2 locations)
- disconnect the linkage
- remove the 4 carb mounting bolts.
Anything else?
After rebuild, anything I need to know about reinstallation? I assume new gasket between manifold and carb (permatex between manifold and gasket? Gasket and carb?). O-rings for the fuel line? Anything else?
I am pretty sure that 4150 is not original to your engine. Go to the Holley website and you can see if they the cable to install and operate the manual choke, or if they have an electric choke setup. I am pretty sure they have both, as do most parts stores. Sound like you may not be familiar with the carburetor and the choke system. Go the the www.Holley.com tech site and see the instruction section.
DennisI think a new carb w/electric choke is likely my best approach. If that gets me back on the road it will be money well spent. If all goes well I could look for a correct date coded carb then, but I’m assuming that will take some time, so a new carb makes sense right now.
I see a 4150 650 cfm double pumper w/ auto choke for $500+ at Jegs. Allstate carb (ACFI) in Central Islip NY is also very close to me and they come highly recommended. I will continue to research a bit and may post back prior to purchase or if I run into trouble with the install. Many thanks to all.
Bill
Bill
You are going down a rabbit hole with aftermarket double pumper carburetors, there calibrations are usually set rich.
I have learned that most of the time, the GM original parts work better than most aftermarket with stock engines.
If you remove that straight piece of wire between the vacuum can for the secondaries and the mechanical choke mechanism, you will be able to verify the choke does work by opening the throttle a bit and move the choke lever to the back of the engine. That should close the choke blade. There are detents in the mechanism that will hold it in a couple of positions, but I wouldn't depend on them when using it for driving the car.
Almost any aftermarket carburetor you buy will need to be fine tuned to your engine and are generally too rich for your needs. I would tune the 3310 to get me by. It is a vacuum secondary and should be a drivable carburetor although not optimum for your engine.
Rather than buy a new carburetor, purchase an electric choke assembly for that 3310 to get you by for $70 plus shipping. Holley 45-223 Choke Conversion Kit The guys here can lead you thru the installation if the Holley U-tube doesn't give you enough guidance. Save the old mechanical choke set up as it fits most Holleys and maybe you can swap it to someone that wants it.
Just my recommendation.
