[C1] Voltage Ragulator
Old Jun 7, 2021 | 06:32 PM
sgorman3's Avatar
sgorman3
Default Voltage Ragulator
I'm having a charging problem on my '61. I have 11.6 VDC on the battery without it running. I get the same 11.6 VDC on the battery with it running and accelerating it seems to have no affect. How can I verify that I have a problem with the regulator? Thanks
Old Jun 7, 2021 | 06:36 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Simple test: With the engine running at a high idle, ground the "F" terminal on the generator. If the Voltage rises dramatically to 15 - 17 Volts, your generator is good but the Voltage regulator is bad. On the other hand if the Voltage doesn't change, the generator is bad.
Old Jun 7, 2021 | 07:13 PM
65GGvert's Avatar
65GGvert
Take a look at the wiring connectors also particularly at the alternator and horn relay.
Old Jun 8, 2021 | 01:52 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Old Jun 8, 2021 | 04:06 PM
sgorman3's Avatar
sgorman3
Thanks for the info SDVette! Very clear and concise
To Voltage Ragulator
