[C2] Odometer Question
Old Jun 9, 2021 | 03:55 PM
Wayne88's Avatar
Wayne88
Default Odometer Question
Is it normal for the odometer numbers to roll unevenly?
Old Jun 9, 2021 | 04:43 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
it is after someone rolls them back
Old Jun 9, 2021 | 05:26 PM
Wayne88's Avatar
Wayne88
It's my car and nobody ever said it was the original mileage, and I really don't care, it's just a number.
I'm just curious if the way these numbers roll are indicative of an original odometer.
Old Jun 9, 2021 | 05:58 PM
Nowhere Man
Also once they go past 100k miles they can look that way too
Old Jun 9, 2021 | 06:33 PM
56early's Avatar
56early
Who should know better,
Old Jun 10, 2021 | 12:23 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Yes, it is totally normal for the numbers to be misaligned – especially as they approach a major rollover and after one. Being over 100k won't make any change to alignment characteristics that wasn't evident before 100k. Between each number wheel is a thin plate with a small "button" on it. Simplistically, as the wheel to the right approaches a complete revolution, the wheel contacts the "button" which then contacts a boss on the next wheel and gradually pushes it to advance one more digit. The higher the place value, the more gradual and pronounced the "misalignment" for a longer time.
Old Jun 10, 2021 | 10:42 AM
barkingrats
I have my odometer out of my "72 and took a closer look at the mechanism between the number wheels. It's actually a small gear captured in the thin plate. The number wheels have teeth on the inside lip of each side; the right hand wheel drives the gear. Regardless, it's a slooooow process to advance the wheels the more left you go and the numbers gradually change. It's not a quick snap to the next digit.
To Odometer Question
