Water Pump
Old Jun 17, 2021 | 06:50 PM
narlee's Avatar
narlee
Default Water Pump
Does anyone make a quality standard water pump anymore? Looking for my non original '61. Am I stuck with Chinese or high performance aluminum? Thanks.
Old Jun 17, 2021 | 10:43 PM
Duck916's Avatar
Duck916
I bought a water pump from RockAuto a couple years ago. Cost about $20. Works fine.
They have a range of pumps from $18 to $105. I don't remember which one I bought, but it's a pretty simple item.
Old Jun 18, 2021 | 12:32 AM
narlee's Avatar
narlee
Thanks, wondered about quality out there now.
Old Jun 18, 2021 | 01:01 AM
benrep's Avatar
benrep
2025 c1 of the Year - Modified Finalist
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
I use this guy. The flying Dutchman. If your housing is good he turns it into a state of the art water pump with later model seals etc. I have had him do a few for me. An old Chrysler Hemi pump and an old GMC 228 six pump. My 327 pump will be heading to him soon. It's old school work at a very reasonable price. Fast turn around in my experience. He seems to be pretty popular in the restoration world of obscure stuff.
http://water-pump-rebuilders.com/
Old Jun 18, 2021 | 05:53 AM
R66's Avatar
R66
I purchased a china water pump thru RockAuto and had problems with leakage at the joint to the block. I set it on the bench and found the right and left surfaces were not properly milled and I had to use two gaskets to get it to seal. It's been quite a while now and the pump is doing fine and the gaskets are not leaking. I have a few old GM pumps and have considered rebuilding one as a spare, but my to do list keeps getting longer here in the woods.
Old Jun 18, 2021 | 08:42 AM
Tampa Jerry's Avatar
Tampa Jerry
I know Zip sells a rebuild kit. You will need a small press to install the bearing. Jerry
Old Jun 18, 2021 | 09:03 AM
Robert61's Avatar
Robert61
If nothing else I am persistent. I had my Edelbrock water pump chromed. I called them and asked for a rebuild kit several times. There policy is you must send it back for rebuild, they say it's not a field serviceable unit. I agree that the average person couldn't do it but in reality it's not hard. The fan and impeller size are different so that made it harder to find the parts. I knew full well that they were going to say we can't rebuild that you've modified it. But I came across this place, ASE industries, and stumbled across the actual part number for the bearing. I ordered a bearing and 2 seals. Very cheap and I did it myself. I highly recommend this place.
https://aseindustries.com/
Old Jun 18, 2021 | 09:05 AM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
I had mine rebuilt by Chevycool. Seems to me it was ballpark $100. Still in the box so I can't comment on how it works - yet. But since you asked for options, that's one to consider rather than buying something of unknown origin and quality.
Old Jun 18, 2021 | 09:10 AM
Robert61's Avatar
Robert61
If nothing else I am persistent. I had my Edelbrock water pump chromed. I called them and asked for a rebuild kit several times. Their policy is you must send it back for rebuild, they say it's not a field serviceable unit. I agree that the average person couldn't do it but in reality it's not hard. The fan and impeller size are different so that made it harder to find the parts. I knew full well that they were going to say we can't rebuild that you've modified it. But I came across this place, ASE industries, and stumbled across the actual part number for the bearing. I ordered a bearing and 2 seals. Very cheap and I did it myself. I highly recommend this place. I have a strong suspicion that this is where Edelbrock buys their parts.
Old Jun 18, 2021 | 09:11 AM
GUSTO14's Avatar
GUSTO14
I picked up a GM Performance parts, aluminum water pump a few years back at Carlisle, new in the box for under $50. Didn't need it, but can't pass on a good deal I might need in the future.
A year or two earlier, I passed on a Stewart Stage II, aluminum water pump, for a C4 L98 for $75 (it sold at the time for over $150), because I didn't need it (I have an '85, but it only has 8,500 miles on it) and it was early in the show. After about an hour, I thought better of it and went back to pick it up 'just-in-case' - it was gone! I don't pass on deals like that any longer. Even if I didn't need it then, either I or someone else would sooner or later.
Good luck, and check out JEG's or Summit. They often have good deals on items like water pumps.
GUSTO
SILENT BOB's Avatar
SILENT BOB
From: Tank sticker? I ain't got no tank sticker! I don't need no tank sticker! I don't have to show any stinking tank sticker!
R66 - Do you have an original L79 pump you'd like to sell?
Old Jun 18, 2021 | 09:31 PM
R66's Avatar
R66
Bob,
Off hand, I have to say no as I don't have any that have the 1/2" pipe plug in the top for the bypass hose. Plus, I have no idea what the correct numbers are for a pump for your car. Tell me the numbers you are looking for and I'll take a look anyway.
Old Jun 18, 2021 | 10:29 PM
Chambered's Avatar
Chambered
Funny you bring this up. Just a week ago I was working with my rep for 2 days - he is primarily an auto parts rep & reps about 70 different manufacturers, as well as heavy duty truck. I asked him who makes the BEST quality water pumps, & made in USA? Answer: GMB. U-Joints: SKF. Ball joints & tie rod ends: TRW.
Old Jun 19, 2021 | 10:46 AM
SILENT BOB's Avatar
SILENT BOB
Thanks for posting.
Looking for rebuildable original L79 pump with 1/2 inch bypass. Numbers not important as they can't be seen when installed.
Old Jun 19, 2021 | 04:20 PM
narlee's Avatar
narlee
Thanks everyone for the response, got a couple of rebuilders and some reputable parts suppliers. Thanks again, Gary
To Water Pump
