Shield, directional arm, plastic?
Old Jul 4, 2021 | 02:48 PM
Joemac8's Avatar
Joemac8
Default Shield, directional arm, plastic?
In replacing the turn signal switch in my 67 L79 (early), there is a small, flat piece of flat plastic with a rectangular hole in the center identified as “Shield, directional arm, plastic” that is sold with the switch. I bought one in case I needed it. After taking the old switch out, I just found the old shield on the floor.
I have looked at all of the books and cannot find where this piece is supposed to go. Anyone know the answer to this?
Old Jul 4, 2021 | 03:00 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
That sounds like the piece that goes on the turn signal arm at the opening on the side of the column inside. Dennis
Old Jul 4, 2021 | 03:08 PM
Joemac8's Avatar
Joemac8
Dennis, you ALWAYS have your $hit together. Thanks yet again!
Old Jul 4, 2021 | 04:23 PM
Bluestripe67
Thanks, but I make my share of mistakes. Dennis
Old Jul 4, 2021 | 04:45 PM
Joemac8's Avatar
Joemac8
Got another bump in the road. I got the upper bearing assembly on. Next is a fiber(.) washer, then a washer and the C clip. When I do it in that order, I cannot see the groove for the C clip. By any chance could it be the C clip first right next to the bearing, then the fiber washer then steel washer ?
To Shield, directional arm, plastic?
