Stuck bulbs?
Old Jul 9, 2021 | 03:48 PM
Joemac8's Avatar
Joemac8
Default Stuck bulbs?
My 67 L79 backup bulbs are stuck. One depresses in, the other not so much. I assume the tail lights will be the same. Should I spray some WD40 to the base of the bulb and let it sit a while and try again?
Old Jul 9, 2021 | 03:50 PM
old60c1's Avatar
old60c1
Si'
Old Jul 9, 2021 | 04:26 PM
CorvetteMikeB's Avatar
CorvetteMikeB
Works for me.
Old Jul 9, 2021 | 04:41 PM
leif.anderson93's Avatar
leif.anderson93
Originally Posted by CorvetteMikeB
Works for me.
As always, a useless suggestion.
Old Jul 9, 2021 | 04:53 PM
csherman's Avatar
csherman
2026 Corvette of the Year Winner - Unmodified
2025 C1 of the Year - Unmodified Winner
2019 C1 of Year Finalist (stock)
2018 C1 of Year Finalist
I break the bulb - (nothing better than driving a glass bulb thru your thumb) ( ask me how I know...)
Then use a needle nose to push down and turn
Old Jul 9, 2021 | 05:10 PM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
I have used that method with 100% success rate more than once. The internal structure allows the needle nose ends to rotate the bulb, in most cases. Worse come to worse, you bend part of the brass base inwards and grab it and push and turn.
Doug
Old Jul 9, 2021 | 05:41 PM
65GGvert's Avatar
65GGvert
I wouldn't use WD-40. PB Blaster or something that will dissolve corrosion maybe. Either way don't try to push and turn with your thumb and finger. Something the glass won't cut through would be better.
To Stuck bulbs?
