[C1] Upper Inner shaft Install
Old Jul 23, 2021 | 02:48 PM
shelljerk47's Avatar
shelljerk47
3rd Gear
Default Upper Inner shaft Install
Good day everyone!
I am rebuilding the front suspension in '58. I'm trying to install the upper inner shafts. I have got them half way through, but they don't seem to want to catch the back side set of threads. Thought it may have just been the back side bushing on the one side. But it is happening on both sides. New shafts, old bushings. And tips or ideas to help me out? I've read several posts on this topic, lots of great info. But I haven't come across anything about this issue. Sorry if this is covered somewhere else, haven't had luck finding anything.
Thanks everyone!!
Old Jul 23, 2021 | 03:05 PM
JF in MI's Avatar
JF in MI
Pro Mechanic
2023 C1 of the Year Finalist - Modified
IIRC, after doing mine, those shafts are directional. This may sound like a stupid question but do you have them inserted the correct way?
Old Jul 23, 2021 | 03:22 PM
shelljerk47
3rd Gear
Was pretty sure I did. But maybe not. After the first set of threads went through the front bushing, thought I was good. But maybe I messed up.....
Old Jul 23, 2021 | 05:05 PM
silver837's Avatar
silver837
Look for threads by Tom Parsons. He is the Forum's guru for C-1 suspensions. He has posted many with how to's
Old Jul 23, 2021 | 05:30 PM
shelljerk47
3rd Gear
I have read his posts. I'm using it to re-do my frontend. That man is a life saver!! I got it figured out. My own stupidity, had them going in the wrong way. Thank you
JF in MI, most of the time its the simplest answer that is the correct one!
Old Jul 23, 2021 | 11:46 PM
silver837's Avatar
silver837
Glad you got it worked out.
To Upper Inner shaft Install
