Rad recore
Old Aug 3, 2021 | 08:20 PM
435er's Avatar
435er
Default Rad recore
Well, Decided to have the original rad in my 66 427 re cored. I perused the shop manual as I like to know what I am getting in to. As I prefer to work alone and not have to disturb any one if it can be avoided. I omitted two things recommend, left the hood on and did not use a helper. It is a ok job if you are a monkey and bare in mind I'm 72. Yes, I did have to sit on top of the engine. Would I do it again? probably but would not look forward to it, hope this new rad does not spring a leak. I did run it and all was good, will be looking for any green spots tomorrow LOL and by the way, its the fan shroud that is the bitch.
Mike
Old Aug 3, 2021 | 08:55 PM
petdoc's Avatar
petdoc
Originally Posted by 435er
".... and by the way, its the fan shroud that is the bitch."
Roger THAT!!!!!
Old Aug 3, 2021 | 09:01 PM
Paster's Avatar
Paster
Originally Posted by petdoc
Roger THAT!!!!!
Absolutely!!
I just got done with the Rad in my 66 427 car, also by myself. I did have the hood removed though. I did it by unbolting the shroud (after removing the fan, clutch, and rad hoses) and moving the shroud rearward over the water pump and leaving it hanging. I was then able to remove the radiator by sliding it between the gap between the support and shroud.
Install was reverse and I was able to get it all back together without scratching everything up.
-Michael
To Rad recore
