Has anyone ever used Water Wetter? My 60 runs a little hotter then I want. Please let me know the pros and cons. I do know it’s not for winter use.
So you are not comfortable with what your gauge is showing. What temps are you seeing? Have you tested with a IR gun pointed at the thermostat housing? How old is your radiator? Your gauge may be at fault. Distilled water and Zerex G-05 is the best. Dennis
Your temperature gauge might not be accurate. Get a DeWitt's Electric Fan Radiator. The built in thermostat kicks in at 195F and off at 175F. No more worries. Doesn't really matter than what your temperature gauge reads.
I used it on my '60 283-230hp and didn't notice any difference.
Most people don't because they do not follow the directions. Wetter water is a surfactant/lubricant that allegedly allows you to run straight distilled water. It is the high content WATER that reduces the coolant system temperature, not the additive. So if you just add a bottle to a 50/50 mix, you'll see nothing.
