[C2] Adjusting solid lifters
Old Aug 23, 2021 | 08:11 AM
Factoid's Avatar
Factoid
Default Adjusting solid lifters
Anyone have Duke’s updated paper? My L72 has an LS6 cam and I believe both lifters are not actually on the base circle when the relevant piston is at TDC on the power stroke. His paper has updated lash specs and the procedure for which valves to adjust every 90 degrees of engine rotation.
Old Aug 23, 2021 | 08:29 AM
FLYNAVY30's Avatar
FLYNAVY30
Mark, see below....
File Type: pdf
Old Aug 23, 2021 | 08:39 AM
Factoid's Avatar
Factoid
Thanks, Greg, much appreciated!
I could have sworn this paper included the bbc cams and specs. Anyone?
Old Aug 23, 2021 | 09:11 AM
FLYNAVY30's Avatar
FLYNAVY30
can't help you there.....this is the only version of this paper I have seen.
Old Aug 23, 2021 | 09:33 AM
Dad's '66 427's Avatar
Dad's '66 427
2020 C2 of the Year Finalist - Unmodified
Another option is to use the EO/IC method..... When the Exhaust starts to open, adjust the Intake. When the Intake starts to close, adjust the Exhaust. Yes, it requires rolling over the motor more, but it works.....
Old Aug 23, 2021 | 09:54 AM
DansYellow66's Avatar
DansYellow66
This is the method I’ve been using as of late. At first I thought it would take forever but it seems to actually go pretty quickly. I usually draw out a sketch showing the cylinder layout, firing order and intake/exhaust valves and just go through each cylinder and record the value on each valve as I go and it goes pretty quick with minimum chance of confusion.
Old Aug 23, 2021 | 10:12 AM
SWCDuke's Avatar
SWCDuke
The LS6 cam is the same as the L-71 cam, which is the same as the L-78/78 cam except this early cam has an oil groove in the rear bearing. The same lobe is used on both sides. If you didn't have a machine shop cut that groove in the later cam your L-72 would have seized up long ago.
For the '65 L-78 the recommended valve lash was .020/.024". For '66 and later it was increased to .024./028". I don't' know why. I do know that the clearance ramp height on the lobe is .012", and 1.7 x .012 = .0204".
Like small block rockers the big block rocker ratio is not constant, but I don't have a reliable data set of rocker ratio behavior through the full range of lift.
Duke
Old Aug 23, 2021 | 12:35 PM
Factoid's Avatar
Factoid
Perfect, thanks all.
Old Aug 23, 2021 | 02:20 PM
reno stallion's Avatar
reno stallion
C2 of Year Finalist (appearance mods) 2019
This will put you right on the bottom of the lobe
To Adjusting solid lifters
