HELP! Carter Carb
Old Sep 3, 2021 | 06:48 PM
bubbles21's Avatar
bubbles21
Default HELP! Carter Carb
Top of Carter seems stuck, got all the screws, fuel line, and linkages, tapped the sides, yes, took a small screwdriver to gasket and comes up little, but really stuck, what did I forget? or just keep prying without a sledge
hammer?
did not remove metering rods, does that matter?
Old Sep 3, 2021 | 07:15 PM
Dan Hampton's Avatar
Dan Hampton
2018 C1 of Year Finalist
AFB or WCFB?
Old Sep 3, 2021 | 07:18 PM
bubbles21's Avatar
bubbles21
AFB I "assume" stock correct for '64 327 - 300
Old Sep 3, 2021 | 07:23 PM
tbarb's Avatar
tbarb
air cleaner stud?? metering rods don't matter
Old Sep 3, 2021 | 08:00 PM
bubbles21's Avatar
bubbles21
I am trying to remove the top - while mounted on the intake - to free up the accelerator pump, because it is not starting unless I prime it - I would think it would pull up over the Air cleaner stud, screwed into the base, not the top, if not, there's is my senior moment..............
Old Sep 3, 2021 | 08:20 PM
plaidside's Avatar
plaidside
Is there one in this hole?
Old Sep 3, 2021 | 08:21 PM
bfitz241's Avatar
bfitz241
I miss that one last time I took the top off.
Old Sep 3, 2021 | 09:25 PM
R66's Avatar
R66
My AFBs have an air cleaner stud with a ferrule around it that also holds the top to the carburetor body.
Old Sep 3, 2021 | 09:57 PM
bubbles21's Avatar
bubbles21
Plaidside - You are the man! I just went out to the garage, and yes, it has that hole, and yes there is a screw in it that I missed, will take it off tomorrow and that will do the trick - thank you Corvette buddies - I did not see that at all - big help..........now onto why the pump are clogged preventing it from starting............
Trip
Old Sep 4, 2021 | 07:14 AM
plaidside's Avatar
plaidside
A couple of thoughts.
The accelerator pump is usually made of leather. Before installation I soak it in oil while I am assembling the rest of the carburetor.
Make sure the spreader spring is in place.
Below the squirted make sure the check ball or pin is not stuck in the passage.
Make sure the 'S' link between the pump shaft and the throttle link is oriented correctly.
Joe
To HELP! Carter Carb
